I'm sorry to hear about the problems you are having with your LiquaFeed Sprayer. Your water pressure needs to be at least 45 PSI. If your garden hose is longer than 50 ft, this can lessen the water pressure. If there is any foreign matter or crystalization on the bottle or the sprayer where the bottle inserts, this will need to be soaked in warm water, as it may be clogging the sprayer. With the bottle of LiquaFeed apart from the sprayer, squeeze the bottle to see if any product comes out. If none of these troubleshooting steps help, please call us at 877-465-5160, and we will be happy to assist you further.
Hilary @Miracle-Gro
I have problems also, too bad that the directions didnt say do not use with a hose more then 50 ft. ! now i am stuck with 3and 1/2 bottles as I bought a four pack ! My qyestion is can I open these bottles and use the product like the regular Miracle Grow Liquid ?
SOLVED!!! I was ready to give up as well, but after "failing" with multiple dispenser units, I decided to see if maybe the bottle was to blame... And I think it is! I removed both the bottle and the dispenser from my water spigot. I took the bottle and removed both the green cap and black gasket. I then took the dispenser, turned it upside down, and screwed the dispenser onto the bottle. Next, I turned the dispenser right side up and attached it back to the spigot like normal... No visible leaks. I turned the water on, set the dispenser to "feed" and bingo! Works like a charm. I think the gaskets on the bottles are the problem. Either that or the nipple on the dispenser is to short. Hopefully this helps... This product is great when it works!
Where the liquid bottle screwes into is the same as a garden hose thread. Inscrewed it into a garden hose and flushed it for about a minute and it worked like a champ.
Maybe they should print the info about the water pressure and also the length of hose and people want waste the money on this item. Question, they have a new one that is placed at the faucet so this should not have a problem with the hose length correct?
if the water pressure is low like in a drip system, i removed the rubber valve in the bottle. just push it in, it floats so with the bottle in position upside down it does not interfere with the outflow. just becareful not to squeeze the bottle once loaded in the device as it will spill out. with this works like a charm even in low flow and pressure systems.
