Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Sep 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Craftsman Door Opener Model #139 53975SRT1 1/2 HP the wall mounted unit push button works great, but the small lite began blinking last week and then my remote stopped working. I got a new battery for the remote, but it still doesn't work. How can I fix this?
Anonymous
Level 3:
President:
  • Master 3,197 Answers
  • Posted on Sep 19, 2011
Anonymous
Master
Level 3:
President:
Answers
3197
Questions
Helped
1458008
Points
8183
Press and hold the lock button on the wall control for 3 seconds. This will stop the blinking and your remote should work.
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
4helpful
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
2helpful
I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
1helpful
Garage door remote does not open door
I think you'll need to reset the wireless connection. Try pushing the button on the machine, then something on the pad. (or vise versa)
8helpful
One of the buttons has a lock icon. Hold that button in for 3 seconds.
Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
I think I've accidentally activated the lock feature...
does logic board on motor have a small pushbutton or dip slide switches? If pushbutton, push it for 10 seconds. let do. panel light stop blinking? Unit somehow got into lock mode, even though you do not have lock button. If this has stopped light from blinking, you now have to code remotes and or keypad back in. Push the little buton for 1 second and push a remote. Light bulbs on unit should blink. Take next remote (or keypad) and repeat this sequence for each one. Let me know. If you have safety beams, liftmaster should help you. w/o beams they will not support.
466helpful
14answers
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks [email protected]
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
