Cars & Trucks Logo
Posted on Sep 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have had my sensors scanned an all are reading on scanner, when i activate tire learning mode the front will read but the rear wont read at all, have grounded the antenna remove the caps, let air out an in tires, still no results, hope you can help, thanks.
robert wales
Level 3:
  • Chevrolet Master 4,977 Answers
  • Posted on Sep 18, 2011
robert wales
Chevrolet Master
Level 3:
Answers
4977
Questions
0
Helped
1331059
Points
59541
Most of these cars you have to drive the car to reset the tire monitor to get a reading on it.the monitor can`t reset if the car isn`t driven so it can monitor wheel speed as this is how it knows if a tire has too little air in it compared to the other tires.less air more wheel rotation(has to spin more to keep up to other wheels),more air less wheel rotation.
2answers
Chevy Cobalt TPMS issue
Most GM cars can be done by holding both lock and unlock buttons on the key fob. The horn will then sound and the you let the air out of the tire. The hot will sound once detected. Start at the left front and then the right front, right rear and left rear. The horn will sound again indicating the procedure has been completed.
Help with learn mode.How to? sorry,it's a 2007 versa sl hatchback,not a sentra.
To activate a new transmitter in the tire pressure monitoring system WITHOUT the Nissan Consult scan tool: Under the dash above the OBD II connector is a single wire connector called the "tire pressure warning check connector". Use a jumper wire and ground the tire pressure warning check connector with the key OFF. Then turn the key ON and cycle the ground at the tire pressure warning check connector 5 times within 10 seconds of turning the key ON. This should cause the tire pressure monitor light to start flashing indicating the system is in "learn mode". Then use the activation tool starting at the left front tire and work around the vehicle in a clockwise direction - front left, front right, rear right and rear left. Activating each transmitter at each wheel should make the turn signal flash one time and after completing all 4 wheels, the turn signals should flash two times and all 4 time pressures should be displayed.
7helpful
2answers
2010 Chevrolet Camaro... My TPMS (Tire Pressure Monitoring Sensor) light came on blinking and car is telling me to have it serviced. only 3 of my 4 tires are registering on the system. Is there anyway to...
There is a Technical Service Bulletin (TSB) for your vehicle stating that if the light is blinking and if there are dashes (- -) on only one or two tire pressure readings, then the tire presure monitoring system should be put through a "Relearn" or "matching" process. Then if any of the tire pressure sensors do not respond while relearning, the sensor in that tire should be replaced.
The TPMS matching process is outlined below:
1. Set the parking brake.
2. Turn the ignition switch to ON/RUN with the engine off.
3. Go to the TPM vehicle information screen on the DIC. Press set to relearn the sensors. The horn sounds twice to signal the receiver is in relearn mode and Tire Learning Active message displays on the Driver Information Center screen.
4. Start with the driver side front tire.
5. Remove the valve cap from the valve stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for 10 seconds, or until a horn chirp sounds. The horn chirp, which can take up to 30 seconds to sound, confirms that the TPMS sensor identification code has been matched to this tire position.
6. Proceed to the passenger side front tire, and repeat the procedure in Step 5.
7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
8. Proceed to the driver side rear tire, and repeat the procedure in Step 5.
9. After hearing the confirming horn chirp, for the driver side rear tire, the horn sounds two more times to signal the tire learning mode is no longer active. Turn the ignition switch to LOCK/OFF.
10. Set all four tires to the recommended air pressure level as indicated on the tire and loading information label.
11. Put the valve caps back on the valve stems.
The tires air pressure will not appear on the screen until you start driving the vehicle.
3helpful
2answers
My front wheel sensor shows low tire pressure, but it is fine. Is there a reset for that?
If its reading low and the tire pressure is correct there is a problem with that sensor. Typically they need to be replaced in order to correct the problem. A TPMS tool capable of displaying TPMS sensor data would confirm the bad reading.
They display the tire pressure as a convenience. They don't have to display the pressures and many makes/models do not.
The level of sophistication with these systems is slowly improving. Many newer models will automatically know where the tire is and display it correctly. Unfortunately yours need to be relearned manually after every tire rotation which is very common with earlier systems. It is assumed that this is done after every tire rotation which would then make the displayed tire locations correct.
If you are confident that the correct tire location is being displayed than I wouldn't see any issue with replacing that sensor. If you are not confident the correct tire location is being displayed than it wouldn't be a bad idea to do a relearn procedure.
engine off.
3. Press and hold the Remote Keyless Entry (RKE)
transmitter's LOCK and UNLOCK buttons, at the
same time, for about five seconds to start the TPMS
learn mode. The horn sounds twice indicating the
TPMS receiver is ready and in learn mode.
4. Start with the driver side front tire. The driver side
front turn signal also comes on to indicate that
corner's sensor is ready to be learned.
5. Remove the valve cap from the tire's valve
or decreasing the tire's air pressure for about
eight seconds. The horn chirp, can take up to
30 seconds to sound. It chirps one time and then
all the turn signals flash one time to confirm the
the tire/wheel position.
6. The passenger side front turn signal comes on to
indicate that corner sensor is ready to be learned.
Proceed to the passenger side front tire and
7. The passenger side rear turn signal comes on to
Proceed to the passenger side rear tire and
8. The driver side rear turn signal comes on to
9. After hearing the single horn chirp for the driver
side rear tire, two additional horn chirps sound
to indicate the tire learning process is done.
If no tires are learned after entering the TPMS learn
mode, or if communication with the receiver stops, or
if the time limit has expired, turn the ignition switch to
LOCK/OFF and start over beginning with Step 2.
level as indicated on the Tire and Loading
Information label.
This info can also be found on page 5-66 of your owners manual.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
1helpful
4answers
I was driving in the snow to work after driving about 45 minutes the svc tire monitor popped up on the radio when I check the tire pressure info the front tires showed what they were and the back drivers...
either a new tyre valve sensor or the reciever ,but in the snow it could have got too cold for the electronics to work ,you might find that when it warms up it will work ok
17helpful
3answers
How do i reset the tpms on a 08 implala SS after a tire rotation,without a owners manual
You have two minutes to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than two minutes, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you need to start over.
The TPMS sensor matching process is outlined below:
  3. Press the Remote Keyless Entry (RKE) transmitter's lock and unlock buttons at the same time for approximately five seconds. The horn sounds twice to signal the receiver is in relearn mode and TIRE LEARNING ACTIVE message displays on the DIC screen.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for five seconds, or until a horn chirp sounds. The horn chirp, which may take up to 30 seconds to sound, confirms that the sensor identification code has been matched to this tire and wheel position.
  8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. The horn sounds two times to indicate the sensor identification code has been matched to the driver side rear tire, and the TPMS sensor matching process is no longer active. The TIRE LEARNING ACTIVE message on the DIC display screen goes off.
  9. Turn the ignition switch to LOCK/OFF.
  10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
3helpful
Have a 2008 Chevy Cobalt, tire sensor is staying on all the tire, not reading the tire pressure at all, has 2 dashes instead. Called and talked to dealership mechanic, he said that re-registering the...
On vehicles equipped with keyless entry, simultaneously press the keyless entry transmitters lock and unlock buttons until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated....Next
  • Increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate....Next
    1. After the horn chirp has sounded and the right front turn signal is illuminated, repeat step 2 for the remaining 3 sensors in the following order:
    1. Right front
    2. Right rear
    3. Left rear
    4. When the left rear sensor has been learned and a double horn chirp has sounded, the learn process is complete and the RCDLR exits the learn mode.
    5. Ignition OFF, adjust all tires to the recommended pressures. Refer to Vehicle Certification, Tire Placard, Anti-Theft, and Service Parts ID Label
    3answers
    2002 lincoln town car wont run over 20 mph and wont rev up the coils have been changed and was not the problem
    Sound like a clogged fuel filter this will keep you from going over a certain speed as the flow of gas is not correct
    1helpful
    Gmc sierra 2008 low tire pressure problem
    You can follow this to reset it.
    Ignition ON, initiate the TPM Learn Mode
    using one of the following procedures:
    1. On vehicles equipped with keyless entry, simultaneously press the keyless entry transmitters lock and unlock buttons until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
    2. On vehicles not equipped with keyless entry, press and release the driver information center (DIC) INFO button until the TIRE LEARN message appears on the DIC display. Press and hold the SET/RESET button until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
    3. Increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
      3.1. Right front
      3.2. Right rear
      3.3. Left rear
    Top Chevrolet Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    john h
    Are you a Chevrolet Expert? Answer questions, earn points and help others
