How can my A330 Fuji be made compatible with a firmware upgrade, which can be downloaded from fujifilm/media/xdtypem? tried this site and can't get anywhere!
If your new card has the letter "H" or "M" on it, your A330 isn't compatible with it unless a "firmware" upgrade is performed on the camera. Here's a link to the process, which you can do by following the steps. https://www.fujifilm.ca/x13573.xml If solves your problem, please rate the help favorably. Thanks
Your new card is probably of the newer "H" or "M" designation, which is not compatible with the A330 unless the camera receives a "firmware" upgrade. Here's a link to Fuji's website with upgrade details and instructions. https://www.fujifilm.ca/x13573.xml If this helps, please rate the answer favorably. Thanks
Your A330 is not compatible with the XD cards that start with an "H" or a "M" before the XD designation, unless you perform a firmware upgrade. You can do it yourself using this link from Fuji Canada. http://www.fujifilm.ca/x13573.xml
u need to upgrade your firmware for A330 as it is not compatible with cards over 512mb. go to fujifilm- accesseries-storage media-xd picture in left hand corner-xd type M. click on link under notice on compatibility. you will find your firmware upgrade here just follow instructions. worked for me
Are you trying to use a new xD memory card?
The A330 will only accept xD cards with no small letters before the disk size.
I have a card "H512MB" and can't use that one.
There is a firmware upgrade to allow you to use a "M512MB" card.
You can see what version of camera firmware you're using by following the instructions here:
http://www.fujifilm.com/products/digital/download/a330/fupd.html
Also tells you how to download the upgrade to use type "M" xD cards.
-Kelly.
According Too Sources. The FinePix A330 is not compatible with H Type memory Cards. That could possibly be the reason it keeps bringing up the write error. Try using a Type M card.
In order to use Type "M" xD cards, you need to upgrade the camera's firmware.
Read here:
Same thing happened to me. I ran across a website that allowed me to download a free recovery program that looks at memory cards. Thankfully this free program allowed me to recover all 232 pictures I had saved from a trip to Spain.
If the new 512mb xD card has a prefix of "H" or "M" before the 512, it is not compatable with your A330 unless a firmware upgrade is performed on the camera. You can download all the details here http://www.fujifilm.ca/x3720.xml
link is dead
