Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
I read that someone has a problem with F-03 on the display.
I have seen this for the first time on my hotpoint wf860 1600 spin.
I read the manual the only thing I can think of
maybe an unbalanced load in the machine. Albeit the
manual is not clear about this. P21 automatic features
unbalanced load warning.
