Proton MM2701VT 27" TV Logo
Posted on Sep 18, 2011
Magnavox about 7-10 years old as soon as i turn it on it turns off and stays off
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
330
Points
My 42 inch sagem tv is overheating, the red light comes on, then 2 lights come on and then turns off, and light stays on. and only turns off when you disconnect tv. When i turn on the tv after 1 min the light flashes, the tv turns off and the light stays on.
3helpful
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
2helpful
My magnavox 52' hdtv won't turn on when you first
replace your STK ICs they are big black ICs will have part # on them call Mats 1-800-628-1118
2answers
Magnavox 37MF331D 37 in. LCD TV tv will not come on, power light blinks. I tried disconnecting power cord and hold power button to discharge, still will not come on and as soon as I apply power again the...
I had the same problem with a Magnavox LCD TV. It would not turn on and the light on the external PSU flashed. I found a replacement 12V 5A power supply on EBAY. It brought the set back to life.
1helpful
My Magnavox TV will not stay on, it takes turning off and on many times before it will stay on.
This may be caused by a protective circuit that is reacting to a momentary failure on the oput put side of the main power supply or a failure in the supply itself.
Depending on the nature of the problem, I would still suggest having it repaired since the flat panel sets, regardless of type, are not lasting as long in service as your Magnavox.
If you decide to replace it with a new set, I wouldn't discard the one you have as long as you have a converter on hand for digital reception. You may be disappointed with a new set quite soon after purchase and want to have the Magnavox repaired after all.
Magnavox DTV box
I would say you got a bad one. They have an auto-shutdown setting, but shutting off as soon as you power it on sounds like a defective converter. How long ago did you purchase it? There should be a 1 year warranty on it. If it is new, return it to the place of purchase. There is also a toll free number on the enclosure that will be able to replace it if it is still under the warranty.
Thanks for using Fixya.
1helpful
Magnavox 37mf321D HDTV won't turn on
It may be touching in the back of the tv on a power point. Yours is doing the same thing mine did before it finely all most burnt up it self and my house The metal casting that the tv mounts on in the tv ,does not have enough room in it. the metal casing touches one of the power supplys in the back and shorts out. If its like my 32'' magnavox flat panel
Tv won't stay on
You could have bad STKs if so replace both of them.Big Black chips on convergence board.
TV turns itself off
I currently work in teir 2 support for magnavox philips and this is a service issue i see alot on random sets hope this helps sorry fotr the bad news.. David
feel free to e-mail me with any other questions at [email protected] thanks.
51MP392 "SAM"error message?
You are in service mode turn the set off and back on again
Turning on
These sets are notorious to have bad components in the power supply, and if you have solid state repair experience, you will need a service manual to repair this SMPS(switch mode power supply) Good Luck
Top Proton Televison & Video Experts
matt martin
matt martin
Bob Kirkwood
Larry
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
