SOURCE: phone freeze unlock code
you need first to have the phone unlock by taking it to a mobile store, then also have them firmware reflash on the phone.
UNLOCK MOTOROLA SYNC
DO NOT TRY MORE THAN TWICE ... u can only do 3 attempts .. if the third don't work u will freeze your phone
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000#
If your phone says wrong password, turn your phone off and put in an
unaccepted Sim Card into the phone (A sim card from another Service
Provider) and then start the process over again. If it says wrong
password even with the wrong Sim card, then you have reached your
second attempt, Do NOT try it again. Instead, go to Ebay and purchase
an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now
that you know your phone's unlock code, (00000000) you can use the
following codes to unlock individual locks on your phone (Where you see
the word Code you will put in your new unlock code, which is now
00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
SOURCE: I need help unlocking my pin code for my phone. ( samsung sgh-g800)
Hi, Did you have any joy in unlocking your pin code? My son has just put a pin code on my g800 to. Could you please let me know what to do.
Thank you.
SOURCE: unlock code
The code is *2767*2878# with no card installed
This is a custom reset to factory default setting
This code is to enable to use your phone if it was locked
To unlock your phone to make it sim free ( any sim card can be use )
There is 2 codes that is necessary
Only 2 codes, do not do a full reset
Installed a non t-mobile sim card
The disply will shown WRONG CARD
Enter *7465625*638*00000000*00000000#
The 00000000 will shown as - - - - - - - -
There are 2 set of 8 zeros
Wait 20 seconds
The next entry will not shown on the display, enter with care
Enter #7465625*638*00000000#
Wait 20 seconds
Turn phone off
Pause
Turn phone on
Enter *#7465625# to check the phone lock status
All locks should be inactive
If NETWORK lock is still active
