SOURCE: water container full but low indication on
I think the water level is read by a magnetic pick up driven by a black floater located 3/4 way towards the back of the water tank.
Make sure this floater can move up and down in its pocket: you can see it through the walls so just shake the tank to see it move, and check that it floats up when you fill water
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
SOURCE: The machine makes a very loud noise when grinding
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
SOURCE: DeLonghi Magnifica coffe maker. Diffuser unit
did you find out what the problem was? mine is doing the same.
SOURCE: The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
