SOURCE: Short Pin/Headphone jack issue with NAD CBE 720 Receiver
It's logical since the headphones jack is connected at the main amplifier. Does your new main amp has headphones out?
SOURCE: I have an NAD T755.
Hi - Not a flash of brilliance I know, but have you switched physically the HDMI cables between the PS3 and STB before connecting to the NAD?
Also - You might try (if you have them) a set of component cables from the STB to the receiver to try and see if the cable box may be having having difficulty with your NAD.
If you can let me know the results of cables switching I'd appreciate it. On a personal note I both love and hate HDMI, having had similar problems 8^)
Good Luck
SOURCE: Have a HD cable set-top
If this is your system;
http://www1.epinions.com/specs/pr-NAD_T742_5_1_Channel_Home_Audio_Receiver
It has two "digital optical" inputs for sound. The video doesn't need to pass through the receiver so, your HD components, box and Bluray player, should hook to TV directly then, providing your TV has digital optical out, you could run your audio out of the TV from a digital optical out, to receiver. This would allow you to select your video through your TV's menu and the sound would come through the receiver through the one input. You can pass your video through the receiver but, it doesn't have the best outputs to handle it. You also may notice lags beteween the audio and video if you go this route.
try pluging it in to the tv HDMI or mabe your receivor is not in the ring output
