SOURCE: I need to have the bracelet of a Swiss legend
There is a store called Fast Fix jewelry and watch repair. I believe they have locations in california. They are usually in the mall. They can size watch bands. A good quality jewelry shop might be able to. And you might just look in the phonebook for a watch repair shop in your area.
SOURCE: I have a swiss legend swiss quarts movement watch.
mcdevito75 here, Possibly the battery is weak, (Need New Battery) or the quartz mechanism is going bad, see the repair service directory here at fixya, bottom of page click on repair service directory then watches.
SOURCE: i have a swiss legend
Most bracelet adjustments require a special tool that is only found in a jewelry store, or your watch can be shortened by the manufacturer. Many watches have pins that push out if you look on the back of the band there should be arrows the pins push in that direction if you have something small enough to fit it the hole, be very careful to put the pin back in the same way. Occasionally some watch bands are not pins they are screws and it can be very difficult to tell the difference between the two. If the watch band has a screw it requires a very small screwdriver and you must be careful NOT to strip the screwhead! You can also shorten some watches by just moving the pin in the band buckle if you have a small tool you should be able to do this yourself, BUT wear glasses because pins will spring out, keep pointed away from your face. Hope this helps!
