Cameras Logo
Posted on Sep 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a nikon d60... is the tamron 70-300 zoom lens compatible ?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Cameras Master 102,366 Answers
  • Posted on Sep 18, 2011
Cameras Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10433373
Points
622693
Tamron makes their lenses with a variety of mounts. A lens with a Canon mount, for example, will not fit a Nikon. Assuming the lens has a Nikon mount then yes, it is compatible with the D60. However, the D60 lacks an autofocus motor, relying on the lens to have one. Some Tamron lenses have such a motor, some do not. Such lenses will not autofocus with the D60, but everything else still works, including manual focus.
Is Tamron AF80-210 compatible with Nikon D3000?
This is the tripods and monopods forum, perhaps you would have more luck posting in the camera lenses forum.
Hope this helps
2answers
Want inexpensive 2x af teleconverter for d70 nikon lens 80-200 ed
You can order the Tamron 2x teleconverter here. Be aware that not all lenses are compatible with teleconverters, and you can actually damage some lenses by trying to use them with a teleconverter.
Sigma AF Zoom 70-210mm F4-5.6 Nikon Mount Camera Lens. is compatible with the nikon d60?? this is the Serial #1172609
Yes, the lens is compatible with the D60, with one proviso. The D60 lacks an autofocus motor, relying on the lens to have one. This lens does not, so the autofocus feature will not work. Other than that, everything else will work.
Aug 27, 2011 • Cameras
1helpful
Autofocus stops after heavy usage
Maybe cleaning the gold coloured contacts on the back of the lens and the ones in the camera may help. Worth a try!
I bought a used Nikon D60 from a friend, used it a
Christine
Is it a Nikon mount indeed. What a question!?! Couldn't fit any other mount on the camera!!! Just a guess here, the lens is probably not aa AF-I, an AF-S or a DX lens. The D60 has limited lens usage. The lens types mentioned are the only ones that fully work on the D60. It will work with G types as long as they are also AF-I or AF-S. AF and AF-D lenses will not auto focus. Hope this helps. Will
Quantaray 100-300mm Lens for Nikon
Yes the new nikon D60 needs lens with a built in a/f motor. Your lens will go on and work but you will
have to manual foucs
Lens not mounted...
Bad lens. But go to camera shop with lens just to confirm.
3helpful
4answers
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
