Televison & Video Logo
Posted on Sep 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a Samsung DVD-V6800 Will not play a dvd regional 1
john morgans
Level 2:
Sergeant:
  • Expert 339 Answers
  • Posted on Sep 17, 2011
john morgans
Expert
Level 2:
Sergeant:
Answers
339
Questions
Helped
127192
Points
999
Make sure the player is switched on, and is at the Samsung logo
screen. Also check the tray is shut and that there's no disc in the
player.
Now press the REPEAT button on the remote, followed by a five digit
code. This code is different depending on what region your player is
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
If you've done this correctly (and your player is compatible with the
hack), you should see a number at the top left corner of the screen
corresponding to the current region.
Now, pressing any number from 1 to 6 will change to the corresponding
region. Or, press 9 for auto-region mode.
Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD
POWER) on the remote to close it and put the player into Standby mode.
The next time you turn your player on, the new region will be set.
Don't forget that if you want to hack it again, you'll need to use a
different code, as listed above. If it's currently set to region 9,
use the code for the last *proper* region you set it to.
hope this helps
John
Changing area regions on DVD
please follow this steps and fix it. Merry Christmas.
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Hi, I have a samsung dvd/vcr combo player model number v6800 which I hacked to be region free. It now plays dvds with region codes regardless from where they originate (ie; 1 or 4), however, some of my...
If the dvds which are "all regions" are recorded from a computer, your dvd player may not play them. I assume the dvds which have a region code have been professionally prepared. Sometimes, the cheap dvd players will play anything while the more sophisticated ones will give you trouble unless everything is just perfect.
3helpful
Change region code on a samsung v6800
This is not promised to work but a known hack for your model of DVD player is...
player.
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
People have reported a problem with the codes given however another was posted (57538) try that one to!!
11helpful
2answers
Unlock code samsung dvd-v6800
i have done what you have write about region free for Unlock code samsung dvd-v6800 and i can not see nothing on my screen
Regional codes
you can buy or download a disc that you put into the dvd player and it will unlock it to all regions
4helpful
I have Samsung DVD Video Combo
player.
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
If the above codes don't work try 57538.
Hope this helps.
I have just purchase a samsung dvd-v6800 dvd/video player. I am unable to play some dvd's that are not region 4. Is there a solution for this? Thanks, Helen
I have just purchase a samsung dvd-v6800 dvd/video player too.
Could you please help me with setting up region free?
[email protected]
Thanks, Yun
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
