SOURCE: tank has slight wobble after installation
you need to tighten the nuts under the tank. the tank is not even.
The best method is hand tight the nuts to approximately same pressure on all 3 nuts. then use socket ratchet, one turn each,one at a time, till the tank stop rocking. stop right there. flush the toilet, check for leak. tighten as needed.
make sure all 3 nuts have even pressure.
SOURCE: How tight is the tank/bowl supposed to be a
They only need to be tight enough to sufficiently seal the donut between the tank and the bowl. Some movement is acceptable. It is better to be a little loose than to overtighten them and risk cracking the tank.
SOURCE: how to assemble tank to bowl
Good Luck and have a Great Day. Please give a 4 THUMBS UP if this free answer was helpful. THNX
SOURCE: We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
SOURCE: Need a flush valve / float assembly for my one
1-800-891-0896 http://www.efaucets.com/f/jacuzzi-ez33-959.shtml
Check this web site out I hope it will help.
