SOURCE: Morotorla ROKR E8 Transfer files
Yes can if you don`t have an software you can get it at this adress http://rapidshare.de/files/34829443/MPTools_4.04b_Full_by_soft-best.net.zip
If they ask for a password to open the file after you have downloaded it then you can try this:
Password: Freshwap.com
you will be directed to rapid share. Then you scroll down the page to the button “free” located at the bottom of the second column. Click on the free button and then you will go onto another page. This page should have a timer counting down. This is how long you have to wait before you can download the file. When the timer expires, then you can enter the 3 character confirmation code that they give you, and then hit download and that’s it.
You will also need WINZIP, that is the software they use to zip the files. This you can get anywhere on the net but you can check: www.downloads.com if you don’t already have it.
Please remember to rate and vote me
SOURCE: Transfer "assigned media" to Micro SD
YOU CAN DO THIS BY MOVING YOUR FILES FROM YOUR MOBILE TO YOUR MEM CARD. THIS FUNCTION IS AVAILABLE IN YOUR MODEL.
IF YOU CANT DO SO. JUST TRANSFER THIS FILES TO YOUR COMPUTER VIA A DATA CABLE AND THEN TRANSFER THE SAME FILES FROM COMPUTER TO MEMCARD USING A MEMORY CARD READER.
HOPE THIS WILL HELPS U.
PLS. RATE MY SOLUTION.
NICE DAY
KETAN
SOURCE: file transfer problem from phone memory to micro sd SGH- D780
samsung D780 sucks when it comes to accessing the memory card. i have the same problem too.
