Question about La Crosse XG-55 Wrist Watch
Changed the battery in my XG-55 and it will not come on...
4 Suggested Answers
SOURCE:
SOURCE: setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
Posted on Apr 04, 2009
  • 9 Answers
SOURCE: The battery of my XG-55 is down. I tried with
When you change the battery on this watch you have to short the circuit board. You need a fine pair of tweezers and you need to look on the circuit board for an arrow or bare spot, put 1 end of the tweezers on that place on the circuit board and the other on the battery at the same time. that should do the trick if the battery was installed correctly and the battery is good.
Posted on Nov 19, 2009
  • 2501 Answers
SOURCE: Lacrosse xg 55 - Do I need to replace the battery?
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for
the small cost saving in doing it yourself.
Posted on Jul 24, 2010
Is watch dead or is battery dead
If your numbers dim when you push any button, it's probably a battery. If your numbers are off or very faint same problem, battery. Those watches take a 1.50 V cell because of the light, and multi functions. Any decent jewelry store should be able to have you in and out in 10 minutes or sooner.
Good luck, gabe.
Oct 22, 2015 | La Crosse XG-55 Wrist Watch
Hi my xg-55 froze up, how do I fix it
You will need to take this watch in to a local Certified Master Horologist. It will have to be opened and reset from the inside by shorting the appropriate contacts on the movement. It may also require a battery to operate properly, if it has not been replaced in the past 1-2 years.
If you wear this watch in the water, you need to have it pressure tested to ensure its resistance after the procedure. This is properly done with a pressure testing machine that usually is found at Horologist / Watchmaker shops only.
Feb 04, 2011 | La Crosse Watches
Lacrosse xg 55 - Do I need to replace the battery? When I use the light nothing displays is this a battery issue? How do I change it if it is the problem?
Jul 16, 2010 | La Crosse XG-55 Wrist Watch
I love my E. Howard radio controlled watch. I recently had the battery replaced by a local jewelry shop but it no longer keeps accurate time!It is about 55 minutes fast and remains that way. What do I do...
mcdevito75 here, Return to the shop that changed the battery for adjustments, possibly a new battery or the factory recommended type battery.
Jul 22, 2010 | Watches
Changed battery now it won't come on
Try shorting the battery case to the watch chassis (using a pair of tweezers perhaps).
This seems to be a standard instruction and I think this resets the watch.
Apr 24, 2010 | La Crosse XG-55 Wrist Watch
How do you calibrate the compass for a Lacross XG-55 wrist watch
Here is the manual for your watch. It tells you how to calibrate the compass. Print out the manual and keep for future reference.
http://www.lacrossetechnology.com/xg55/manual.pdf
Good luck. Did this help you?
Jan 12, 2010 | Watches
The battery of my XG-55 is down. I tried with several watch repair labs, but they told me that after changing the battery, the watch doesn't start again. Any advice?
Nov 18, 2009 | La Crosse XG-55 Wrist Watch
Error after changing battery in polar watch
Follow this link:
http://www.polar.fi/en/support/product_support?product=125
This is original Polar support site.Here you will find all the info available.
Rate me, please.
Mar 28, 2009 | Polar F6 Wrist Watch
Setting the altimeter on the la crosse xg-55
Sep 03, 2008 | La Crosse XG-55 Wrist Watch
Owner manual
Go up a level, then select your model.
http://www.gsi-usa.com/instructions/
I found my Coleman 40-842 there.
Sep 15, 2007 | Watches
La Crosse XG-55 Wrist Watch Logo
70 people viewed this question
Top La Crosse Watches Experts
Arturs Kalnins
Arturs Kalnins
Thomas Perkins
Thomas Perkins
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
