The clicking is made by the laser head as it moves across the surface of the disk repeteadly trying to pick up the data signal and failing.
If it has used to work then it's clearly a dirt problem. If a cleaning disk has failed to work then the dust has gone all the way to the reading sensor. To clean it you will need top completely dismantle the unit access the optical mechanism, take off the cover and access the reading head - there blow with the can between the lens and the sensor then with a q-tip wipe the surface of the lens.
