Question about Motorola Mobility MOTOROKR Z6 Cell Phone
I have my motorola z6 it is functional but the problem is the flex is damage i the option part and call keys cannot function.il bring to motorola services but they says that theirs not parts available so what could i do the cost of that phone before is expensive il buy that for almost 15k not theres no services at all.
Razor v 3 keypad will not light up,everything else is fine
Hi,keypad light issues for Motorola phones are usually caused by the flex of the phone and also the Keypad IC.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
also When buttons on a cell phone does not work , it is usually a problem from the Board of the cell phone. An IC problem...
IC are small chips that has different functions on the cell phone. Each IC chips on the cell phone has it's function. The IC controlling the function of the keypads npt working is damaged and needs to be replaced.with another IC chips.
You can get IC chips from your mobile company mini office or you can simply go to the nearest Expert repair store around you area to replace the damaged IC chip that controls the key pad not working.
Sometimes, it might just be dirt or water spill that is making it not to function. You can open the cell phone and clean the keypad area,
Hope it helps.
Thanks for using fixya...
Jun 15, 2011 | Motorola Mobility RAZR V3
My phone display blink
Hi, samsung phones with blinking display is usually caused by the flex of the cell phone,.
It can be fixed.There is a common fault for all Samsung cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
Hope it helps.
May 25, 2011 | Samsung Star GT-S5233 Cell Phone
Hi all the buttons on my LG Prada KF900 mobile have stopped working. The touch buttons are fine its just the actual "real" buttons ie. the two on the front and all down the sides. Any idea whats...
Hi, no need to get a new phone, It can be fixed.There is a common fault for all LG Prada KF900 cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
Hope it helps.
May 24, 2011 | LG Prada KF900 Cell Phone
My droid 2 screen goes black when some calls i cant answer it at all i have to take battery of the back to stop it from ringing
Hi, It can be fixed.There is a common fault for all Motorola cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
Hope it helps.
May 24, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
MOTOROLA DROID SCREEN IS BLACK BUT IT IS ON
There is a common fault for all MOTOROLA DROID cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction .That's what makes the screen to go black.
Hope it helps.
Mar 12, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
When i pressed any button that give error < voice record >
Hi,what causes the phone to give such error <voice record>,is because there is a flex that controls the voice key when the flex is damaged it can cause such problem.
The flex is located at the top of the phone, where the screen is located.When you remove the back cover where the smaller screen is,you will located where the flex is. The flex also controls the side key function.
When you replace the flex,problem solved.
Thanks for using fixya.....
Oct 21, 2010 | Motorola Mobility RAZR V3
My settings menu are not working, i cant asess my menu
Hi,problem can solved..What makes the menu button not functioning, is because the flex of the phone is damaged.
The flex of the phone is located inside the phone and it is connected to the display of the phone. And also controls the functions of the menu key.
The flex might have cut or might be damaged and will need to be replaced with another.
When the flex is replaced,problem solved.
Oct 20, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
All buttons have stopped working
Hi, different possible places to check,
The flex,
keypad IC.
The flex of the phone.
The flex is connected to the screen and it makes the screen display,Also if the flex gets damaged it will make the key pad not to work.
The keypad IC is found inside the phone boardand it make the keypad the function.If IC gets damaged, might cause keypad noe to function.
It depend of the keypad your talking about, if it's the lower key pad or the upper keypad where the menu is.
If it's the upper keypad is damaged, that means the keypad area is faulty,and will need to be replaced.
Have a nice day.
Sep 03, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
Motorola Mobility MOTOROKR Z6 Cell Phone Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
