Nokia N70 Cellular Phone Logo
Posted on Sep 17, 2011
Settings for my n73 device manager - Nokia N70 Cellular Phone
Rakib
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 25, 2017
Rakib
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
168
Points
How i can updated nokia n73?
I can not any sowfter install?
1helpful
How to format a nokia n73 phone?
You can format your Nokia N73 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YES
NOTE:
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings.
2answers
I AM NOT ANY SOFTWARE INSTALL MY NOKIA N73. BECAUSE CERTIFICATION ERROR
format your n73.
Formating method.
1. Switch your n73
2. Now "press and hold" the three buttons(call, *,3)
3. Switch on your phone by holding the 3 switches.
Its working..
10helpful
Abut certificate error i n73
Do the following:
  1. Open the Application manager by selecting Menu > Installations (or Applications orApps. or Ctrl.panel or Tools) > App.mgr.
  2. Select Options > Settings.
  3. Set Software installation to All and Online certificate (or certif.) check to Off.
  4. Retry the installation again.
1helpful
Settings
you need to contact your service provider. just tell him/her the model of your phone (which is Nokia N73) and they'll send you settings via text message. just save the settings (you may prompted to enter pin code provided by network) and restart your device.
be sure to activate gprs first before sending multimedia messages..
1helpful
I want to get the default memory as for memory card
Hello Saurabh,
Do you mean you want to set your memory card as your N73's default memory to store data? Well, here's how:
For Videos, select Options > Settings >> Memory in use — it define the default memory store: device memory or memory card (if inserted).
For Messages, select Message > Options > Settings >> Memory in use
For other settings, you may want to check out the manual here:
http://nds2.nokia.com/files/support/apac/phones/guides/Nokia_N73_APAC_UG_en.pdf
Hope this helps.
1helpful
2answers
Didnt connect bluetooth headset to N73
Sometimes what happens is that we keep looking for BT devices without making them visible. Is it so in your case too? Go to settings of the headset and make it visible and your mobile visible to the headset. then you must pair them and also authorize them to connect without pass code etc. Then they will work.
1helpful
2answers
Certificate error if i install themes to my n73
This problem is because u don't turn off u r software installation from setting menu do do This follow simple steps
1> open menu > tools > App. manager
2> click on Options> settings
3> turn off software installation from Signed only
4> Turn OFF Online Certif. check
its done now u can install thems & other softwares to.
1helpful
My nokia phone N73 could not get the PC how can i manage this
you should have Nokia PC Suit installed in your computer connect your phone using Nokia N73 compatible data cable (DKU-2). and you'll be good to go..there is no need to install any drivers for data cable or phone specially..pc suit has it all..
3helpful
3answers
Sis intallation problem in N73
hi,
dear there is way to install a sis file in NOKIA N73
coz its N-series mobile higher.
you have only install sisx,jad,and jar files
if you want to get some files tel me i will tel you links were you can ezzzely
1helpful
Connecting my PC to Internet through Bluetooth, using Nokia N73
Try opening Nokia PC Suite, click settings, then Manage Connects. Check the "blutooth" check box as well.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
