SOURCE: my bunn coffee maker leaks
Experiencing same problem. Appears there may be a recall depending on your model and production date. I suspect it is the small seal washer where top fill tube attaches to the top of the tank. Water leaking here would flow done inside the round steel body and leak out bottom.
SOURCE: BUNN BX-B Coffee Maker Leaking
is it the water container that leaking the best thing to do is open it maybe is a loose pipe or dry pipe connected to water container and if it the water container use 5 or 1minute epoxy cheers
SOURCE: Bunn Coffee Maker Leaks out the bottom
Contact Bunn and they will send you a free repair kit with good illustrated instructions.
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
SOURCE: Bunn (Pour Omatic) coffee maker
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
