Bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
This problem can be repaired most of the time, by replacing battery and a download to clear tamper. Call Frank @ 775-338-6634.
Bad RTC Chip - Verifone recommends replacement of the unit but the circuit problem can be repaired by a professional. You can contact FMI at [email protected] and get details of what you can do. I know this can be a real pain but in most cases you can get help without buying another unit. I hope this helps.
SOURCE: I have two verifone vx510 cc machines. 1st) Need
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
SOURCE: I have a VeriFone VX510 and it says "Bad RTC Chip
