As long as it still has a recovery partition you can get it back to the factory settings. Make sure its turned off first now press and hold down the 0 (zero) key while powering on the computer. When the computer powers on the TOSHIBA HDD recover screen displays. Just follow the prompts ........cheers from Scott
it will delete everything (all other software I have installed and all Data from comp) EXCEPT the anti -virus and the vista package cause they were only installed a couple of months ago?????? If it does delete absolutely everything how do I get the windows vista and anti virus with out the cd or activation codes etc ??????
You havent said what data you are trying to get rid of.........if its just some personal files just manually delete them or manually remove any programs you dont want to sell it with. You really need a back up device.......i recently bought a USB external HDD 500gig for $50 well worth the investment
sorry I want to get everything absolutely deleted except the windows vista & the anti virus I installed a few months ago but like I said don't have the activation codes or the CDs to put them back on to go to the new owner as I have stated that they are on there.
just go into control panel ..programs and features and manually delete them all.......you cant really do it any other way without installation media
3. the following screen a window with your username appears.
Type your windows password as you would log on to your account and press "OK":
4. The next screen offers several options to repair or diagnose your computer system.
To start the recovery, click on "Toshiba HDD Recovery":
Step 2 - Performing the HDD recovery
1. After passing the previous screen, you will be asked if a backup of your important data is already made.
You can continue with the recovery process by clicking on "Next"
2. Confirm the following screen also by clicking on "Next"
3. You will be asked again if you want to recover your machine (and delete all files on your harddrive).
There are no additional options regarding the harddrive, which can be set. Click on "Yes" to start the recovery.
4. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
5. By pressing the "Restart" button to restart the machine, the recovery procedure is almost finished
Step 3 - Finishing the recovery process
1. After the successful completion of the recovery process and the restart of your machine, the following screen should appear.
2. The installation wizard of Windows Vista / Windows 7 will start
up to guide you trough the setup for your newly installed system and to
finish the installation of the operating system
FOR WIN 7 Toshiba System Restore Windows 7
How to recover a Toshiba with the HDD recovery procedure
- Operating System: Windows 7 - 32 Bit, Windows 7 - 64 Bit, Windows Vista 32 Bit, Windows Vista 64
Bit
The following guide describes how to recover a Toshiba with a preinstalled Windows windows 7 from HDD through the
"HDD recovery procedure".
Please note:
First of all, make sure you already back up your important data!
Step 1 - "Initiating the HDD recovery procedure"
1. Switch on the computer and press "F8" key while Toshiba logo appears. You will see the following screen.Choose the
entry "Repair your Computer" and press "Enter":
1. Wait till the following screen appears, choose the keyboard layout which matches the language of your keyboard and
click on "Next".
If unsure, just click on "Next".
1. In the following screen a window with your username appears.
1. The next screen offers several options to repair or diagnose your computer system.To start the recovery, click on
1. After passing the previous screen, you will be asked if a backup of your important data is already made.You can
1. Confirm the following screen also by clicking on "Next"
1. You will be asked again if you want to recover your machine (and delete all files on your harddrive).There are no
1. The recovery procedure starts immediately by formatting the harddrive and copying all needed files to the harddisk
appear.
1. The installation wizard of Windows Vista / Windows 7 will start up to guide you trough the setup for your newly
installed system and to finish the installation of the operating system
Hope this helps,
Hope this helps,
