Look for a small hole in the bottom of the faucet handle,, it holds a allen type or a slotted screw for retaining the handle,, ( more than likely on a moen or Kohler its going to be a allen head,) ,, remove that and your handle should come off
check this link , Just in case you have this type of handle,. it has a complete breakdown in a diagram that you can see, and you might need to unscrew the skirt alsohttp://www.terrylove.com/forums/showthre...
SOURCE: delta faucet is loose ;moves right-left/wobbles. Tightening?
Try tightening the allen set screw behind the spout "you need a special (allen keys) to do this, and one should have came with your faucet". You can also buy or borrow an set of them.
http://www.efaucetscomplete.com/SpecSheets/T2755CBLHP_Install.pdf
Copy and paste this to your address bar for directions.
SOURCE: How to tighten Moen Handle...Not leaking, just
There is a set screw at the base of the handle on the back side, could be alen or regular screw driver type. This link will help you find it.
http://www.moen.com/shared/pdf/7825pt.pdf
Testimonial: "Thiswas very helpful and very much appreciated! I saw the logo type button but did not realize it came off, although I thought it might come off. Thx!"
