SOURCE: how to download softwares to my sandisk u3 flashdrive
As you may know your U3 Smart drive has a small OS that allows you to run Your applications on another computer. This OS shows as a CD-ROM icon on which you click to execute the LaunchPad (TheOS) of the Cruzer. In addition to that you have the icon of a regular drive. (Usually the Drive letters are consecutive G and H for exemple.) When you safely remove one both are unmounted at the same time.
Once the LaunchPad has been executed, it installs an icon on the sys-tray. When clicked, that tray icon opens a pop Up window, giving a menu of the applications installed and which you can run on the host computer, but from your drive (U3 Smart Programs on the left) and on the right various menu options
So if you want to download additional U3 Programs to run from you drive you use the Add programs (option 3 in the list above)
However, if you just want to put regular files on the drive (pictures, text documents, etc.) you do as you woul for nay drive: You drag and drop the files, not on the CD-ROM icon, but on the other drive. You can also use the Explore option (option 1 in the list above) to open the second drive to see what is in it, add files, remove files etc.
Hope it helps
SOURCE: hi, i have a Sandisk cruzer micro 16gb U3 Smart.
U3 is the software application launcher, download and replace it with an updated version. This being availibile on www.sandisk.com site. Hope it helps
This will get the drive back, but you WILL lose the data. If you need the data. I do not know the answer. Repost your question to go to Sandisk site below
'.............U3 smart drives come preinstalled with the U3 Launchpad
which emulates the Windows OS start menu, and controls program installation and
hence facilitate the portability of software. However, if you would like to use
the USB flash drive or memory key as a pure normal USB mass storage device, or
you don't use operating system that U3 supports (i.e Windows XP and Windows
2000 operating systems), or you simply feel that U3 Launchpad and applications
have bugs such as unable to eject due to locked files in use, consent on
privacy and automatic installation of U3 software and pop-up etc, you can uninstall
and remove the U3 Launchpad from the USB storage device.
To remove and delete the U3 Launchpad, you need to download
U3 Launchpad uninstallers or U3 Launchpad Removal Tool that remove the U3
Launchpad and re-configure the USB drive to be a single mass storage USB drive.
Currently, U3 Launchpad uninstallers are only available for and must be run on
Windows XP or Windows 2000 machine. When uninstalling, the U3 smart drives USB
device has to be plugged in with U3 Launchpad running.
U3 Launchpad Removal Tool for SanDisk USB U3 devices can be
downloaded here, http://u3.sandisk.com/
WARNING: U3 Launchpad removal is irreversible. You won't be
able to install U3 again. Beside, backup your data before begin uninstallation
process as ALL data will be erased.
UPDATE: It's impossible to reinstall U3 LaunchPad........."
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is really appreciated for the FREE answering of your question.
