SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
SOURCE: Kenmore Model 16221 sewing machine
your machine needs to be clean take it down clean and oil it up and you will have that problem no more.good luck.
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
SOURCE: Thread knots up under the feed dog plate error LO
No but I will be taking it to a Janome authorized repair shop and pay them thanks anyway. G
