Sir!! how can i install java application with my cherry mobile T2
Although Globe does not support the handset, you can still try to
configure your handset for the MMS/GPRS using this general configuration
setting to serve as your guide.
GPRS Access Settings
APN (Access Point Name): internet.globe.com.ph (postpaid)
http.globe.com.ph (prepaid)
Homepage: http://www.globe.com.ph/globe.wmlc
Bearer: GPRS
Proxy Address: 203.177.42.214
Proxy Port: 9201
MMS Access Settings
APN: mms.globe.com.ph
Bearer: GPRS
MMS Center: http://192.40.100.22:10021/mmsc
Gateway Address: 192.40.100.20
Gateway Port: 9201
Hope this helps
Hello po ...
ndi cu po alam mag manual configure ng t2 cherry
SOURCE: d12 cherry mobile GPRS setting
To get the GPRS setting please call your service provider.
They will send you the GPRS setting.After you recieve please save the settings to your
phone and make it as default setting.
Hope this solves your problem. Thanks for using FixYa.
SOURCE: how to activate Gprs of
First you have to contact your Network provider to ask for the GPRS settings or if your phone is currently supported by the network.
Testimonial: "thank you!!"
SOURCE: set GPRS on my CHERRY
Hi, to access Internet on your Cherry Cellphone you need to activate GPRS and download GPRS settings for your cellphone. Please contact the Customer Care of your Cellphone Network Carrier to download the GPRS settings or to enter the GPRS settings manually on your Cellphone. After the GPRS settings completion and activation, you can access Internet on your Cellphone.
