SOURCE: D-Link DI-524 4 Port connection Problem.
Perhaps the router is not broadcasting its SSID, therefore is invisible to would be tappers. Type 192.168.0.1 into a browser on a computer directly wired to the router, leave the username blank, if you havent changed it, the password is admin by default. Once logged in check that wireless is enabled and that you are broadcasting the ssid, you may want to setup/change security settings for the wireless connection at this time also.
SOURCE: DI-524 status led not blinking
Here are the instructions
Hope this helps.
Also you can visit the link :: support.dlink.com/products/view.···DI%2D524 for further assistance
Please rate this solution!!!!!!
SOURCE: how to put a password on dlink dir-300 wireless network
u have to setup as wep
then enable secure network then set encryption key.wihc is prompt for connect network.
SOURCE: DLink DIR-615 can forward ports
You probably have a 3rd part firewall software on the PC, configure that firewall to allow the same ports. what AntiVirus do you have?
SOURCE: how do i upgrade my firmware on my dlink dl-524?
Go to the following website to download the firmware update for the DL-524. This will save the firmware update to your harddrive:
http://www.dlink.com.au/tech/Download/download.aspx?product=DI-524&revision=REV_B&filetype=Firmware
1. Open the web browser
2. Type in the IP address of the DL-524 router.
3. Type admin in the user name field
4. Type the password you set on this device
5. Click on the Tools tab
6. Click the browse button and locate the firmware file you downloaded and saved to your hard drive.
7. Click the apply button to complete the firmware upgrade.
