According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display:
The attempt to burn a disc failed. An unknown error occurred (4280)
You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present.
Verifying the Model of the CDRW/DVD Drive
Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
- Open iTunes.
- In the iTunes Help menu, click Run CD Diagnostics .
- Insert an audio CD in the optical drive.
- Click OK .
- View the results in the CD Diagnostics window:
- If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
- If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message
When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message:
CAUTION:
Take care in using the following steps.
- Close iTunes and any other files and software that are open.
- Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
- Locate the file gcdrtype.cfg in the CD Configuration folder.
- Right-click the file gcdrtype.cfg .
- In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
- In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
- Locate the line that reads:
DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
- At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads:
DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
- At the top of the Notepad window, click File , Save .
- At the top of the Notepad window, click File , Exit to close the window.
- At the top of the CD Configuration window, click File , Close to close the window
- Restart the computer.
You should now be able to burn an audio CD without displaying this error message.
If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
