Question about Cisco ASA 5520 Firewall
Cisco ASA5520 not accepting new VPN connections
2 Suggested Answers
SOURCE:
  • 101 Answers
SOURCE: how to connect the Cisco ASA 5505 firewall through lan cables?
A conflict in the IP address, resolve it
Posted on Mar 27, 2009
Can CISCO2921-SEC/K9 address these needs?
Please my answers for few questions which you have raised.
· can support 50 to 100 users -- Yes it will support.
· must be able to accept fiber optic connection -- By default one SFP slot is in place with cisco2921.
· can record all traffic for 3 months -- This am not sure. You can raise the buffer size to keep the most of the logs but.
· has built-in firewall that can allow sites for specific hours say (Facebook.com: 12pm - 1pm only) - ZBF can be possible. But am not sure on time based ACL.
· can accept DSL line as backup line (more than 1 line can be supported) --- Yes i hope so it should support.
· can support VPN --- Yes it supports VPN in the Security Bundle
· can support VOIP --- Yes. It supports VOIP.
Please do rate if the given information helps.
Apr 23, 2015 | Cisco2921-sec/k9 2921 Integrated Services...
Tip
Cisco 1841 Router, Hot Sales Product Cisco 1800 Business Router
The Cisco 1841 router is designed for secure data connectivity and provides significant additional value compared to prior generations of Cisco 1700 Series routers by offering more than a fivefold performance increase and integrated hardware-based encryption enabled by an optional Cisco IOS Software security image.<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841</a> dramatically increase interface card slot performance and density over the Cisco 1700 Series while maintaining support for more than 30 existing WAN interface cards (WICs) and multiplex trunk cards (voice/WICs [VWICs]-for data only on the Cisco 1841 router).<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841 router</a> offers embedded hardware-based encryption enabled by an optional Cisco IOS Software security image; further enhancement of VPN performance with an optional VPN acceleration module; an intrusion prevention system (IPS) and firewall functions; interfaces for a wide range of connectivity requirements, including support for optional integrated switch ports; plus sufficient performance and slot density for future network expansion and advanced applications as well as an integrated real-time clock.<br /><br />Cisco 1841 router Product Details<br />Product Description Cisco 1841 router<br />Device Type Router<br />Form Factor External - modular - 1U<br />Dimensions (WxDxH) 34.3 cm x 27.4 cm x 4.75 cm<br />RAM 128 MB (installed) / 384 MB (max) - SDRAM<br />Flash Memory 32 MB (installed) / 128 MB (max)<br />Data Link Protocol Ethernet, Fast Ethernet<br />Network / Transport Protocol IPSec<br />Remote Management Protocol SNMP<br />Digital Signaling Protocol ADSL over ISDN<br />Features Cisco IOS IP Broadband , firewall protection, 128-bit encryption, hardware encryption, VPN support, VLAN support, Intrusion Prevention System (IPS), 256-bit encryption<br />Power AC 120/230 V ( 50/60 Hz )<br />System Requirements Microsoft Windows 98 Second Edition<br /><br />P.S. If you would like a new sealed Cisco 1841, the competitive price offered at RouterSwitch.com is US$586.00 per. Visit Cisco 1841 to see more...<br /><br />Notes: Router-switch.com is a World's Leading <a href="http://www.router-switch.com/">Cisco Supplier</a>, founded in 2002. It sells new, used and refurbished Cisco network equipment including Cisco routers 800/1800/1900/2800/2900/3800/3900 series, Cisco switches, Cisco Firewalls Security, Cisco IP Phones VOIP, etc.<br /><br />
on Jul 07, 2011 | Computers & Internet
Can i set vpn bby using cisco 2513 routers, i am trying to type crypto commands but it is not accepting
You probably have the wrong feature set on the IOS. You would need to download a new IOS image that has the security feature set.
Aug 21, 2017 | Cisco Computers & Internet
Belkin n150 cisco vpn
hi - I just had a tough day trying to connect N150 to my company's VPN, and after a long struggle found out that Belkin N150 does not support the VPN connections. simply upgrade it to N300 and you would be fine.
Jun 08, 2012 | Belkin Connect N150 Wireless Router...
Cisco VPN Client Error
Hello
Try to switch off the Cisco VPN Stateful firewall.
Apr 19, 2009 | Computers & Internet
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cisco vpn sever set up
Here's a tutorial for you on VPN: http://www.computernetworkinghelp.com/content/view/41/1/ As trying to type it down here would just be too much...lol Have fun with that!!
Sep 07, 2006 | Cisco VPN 3000 (LL-VPN3000) for PC
VPN connection problems!
I am not real versed on VPN connections but the only way I was able to connect to my company's Cisco VPN using my Ipaq was with this program. http://www.apani.com/vpnclients.html The whole thing went very easily.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Cisco ASA 5520 Firewall Logo
77 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
