From a quick search just now, (Acer Aspire 5600 processor fan), here is one example,
http://www.laptopcpufan.com/acer-aspire-5600-laptop-cpu-cooling-fan-p-35.html
Here is a link to a free Service Manual for the Acer Aspire 5600 series of Notebook PC's,
(Of which the Acer Aspire 5601WLMi Notebook PC is one of the series),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
In the 'paragraph' that begins with Aspire 1200, go down to the 8th line.
Left-click on - 5600
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
[ I don't know what version it is, but if it isn't Adobe Reader X {10} I would recommend going to Adobe Reader Support, and downloading it,
http://www.adobe.com/support/reader/
Left-click on the Get Adobe Reader, in the small rectangle under the heading Download.
(Has a white Adobe Reader icon, in the red square to the left of, Get Adobe Reader ]
After you click on the file name (5600), it may take up to 30 seconds before you will see the first page come up. (Sometimes a little longer)
It may also take additional time for the file to fully download.
You can save this PDF service manual to your computer.
This way you won't have to download it again, and can burn it off to a CD for safekeeping.
(You can also delete it from your computer after saving it to a CD, and save harddrive space)
If you do not know how, and would like to, please post in a Comment.
BEFORE you begin replacing:
1) Observe Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Buy, and wear an ESD wrist strap, connect it's alligator clip to a good ground source.
{Electro Static Discharge.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You may not have such an animal available. Place a large metallic object up on your workbench, (Table), and connect to it. A large metal serving tray, or large metallic knickknack.
If the table has metal legs connect to one of them. (Unpainted surface, remember)
DO NOT work on a bed, couch, or directly on a carpet floor. These are HIGH areas of Static electricity.
Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
2) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
If a multi-compartment container is not available, (Weekly pill dispenser/container?), use a clean egg carton as a substitute.
Label each egg holder.
Some screws look VERY similar to other screws. DO NOT mix them up.
3) Make a record during disassembling.
It's nice to have a personal record to refer back to in case you are interrupted.
It's also nice to have a personal record to use along with a service manual.
Make sure your notes are legible so you can read them later. Don't get in a hurry.
Make notes, and drawings, and/or use a digital, or video camera.
{Remember to tilt the motherboard when reinstalling. The I/O ports go down into the case first, then set the motherboard down in flat}
While you're in there, use Q-tips, a small soft brush, (Makeup brush?), and a can, or two of compressed air for computers, and clean that baby out.
Pay special attention to the Heatsink, and Fan Assembly.
Note*
The top of the Processor, and the matching flat plate on the Cooling Tube, have thermal paste in-between them.
Same with the top of the GPU, and it's matching flat cooling tube plate.
After time thermal paste dries up. It loses it's conductivity properties then.
If a laptop has been constantly overheating, it may behoove you to replace the thermal paste.
For proper procedures in performing this, post in a Comment.
To explain GPU:
Graphics Processing Unit. The graphics 'engine'.
A Chipset,
http://en.wikipedia.org/wiki/Graphics_Processing_Unit
Chip and Chipset are slang terms to denote I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
This is an article on disassembling an Acer Aspire 5610z Notebook PC.
Using it to show the cooling system for your Aspire 5601, which if memory serves is the same, or very close to the same,
http://www.insidemylaptop.com/disassemble-acer-aspire-5610z-laptop/
Scroll down to Step 7.
The silver looking D shape, and the black fan is the Fan Assembly.
The silver looking D shape is the Fan Shroud.
The slightly flattened curved copper tube is the Cooling Tube.
(The sealed copper Cooling Tube is filled with Nitrogen)
At the top of the Fan Shroud, and where the copper Cooling Tube connects, is the copper, finned Heatsink.
It is barely visible in this photo.
Coming down the curved shape of the copper Cooling Tube is a flat plate. It has an aluminum X on it.
The Processor sits under this plate.
Further down at the end of the Cooling Tube is a small square copper plate.
The GPU sits under this plate.
Air is drawn into the Fan Assembly from the bottom of the laptop.
The air then flows into the copper, finned Heatsink.
Heat is absorbed by the flat plate sitting on top of the Processor's case, and the top of the GPU, and is absorbed by the Cooling Tube.
Heat is then transferred by the Cooling Tube up to the Heatsink.
The fins of the Heatsink radiate the heat away.
The air flow from the Fan Assembly helps to carry heat away from the fins.
It could be that the quality of the fan's bearings in the Fan Assembly, were below par from the factory.
It could be also that the laptop has been dirty inside for quite a while, and this led to the demise of the fan's bearings.
Laptops need to be cleaned inside on a regular basis as needed.
Depends on the environment they are in as to how often.
For additional questions please post in a Comment.
Regards,
joecoolvette
When A/C is requested and the ambient temperature is more than 10?°C (50?°F).
A/C refrigerant pressure exceeds 1310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is more than 117?°C (243?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the engine wiring harness junction block. The ground path is provided at G101.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the FAN CONT #1 relay coil, closes the relay contacts, and supplies battery positive voltage from the FAN CONT #1 fuse through the cooling fan motor supply voltage circuit to the right cooling fan. The ground path for the right cooling fan is through the FAN CONT #2 relay and the left cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the FAN CONT #1 relay through the low speed cooling fan relay control circuit. After a 3-second delay, the PCM supplies a ground path for the FAN CONT #2 relay and the FAN CONT #3 relay through the high speed cooling fan relay control circuit. This energizes the FAN CONT #2 relay coil, closes the relay contacts, and provides a ground path for the right cooling fan. At the same time the FAN CONT #3 relay coil is energized closing the relay contacts and provides battery positive voltage from the FAN CONT #2 fuse on the cooling fan motor supply voltage circuit to the left cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Is your vehicles check engine light lit ?
Is the
When the A/C is requested and the ambient temperature is more than 50?°C (122?°F).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The PCM commands High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110?°C (230?°F).
A/C refrigerant pressure exceeds 1655 kPa (240 psi).
When certain DTCs set.
So
