Question about Mitsubishi WS-65809 65" Rear Projection Television
Good morning, I am in the moving business and have a customer that wants me to move their large TV Mitsubishi medallion tv. She thinks is comes apart in two peices for easy moving and I need instructions and or a manual to do it properly. Thanks, Richard I need a manual for a mitsubishi medalion hd-1080.
  • Mitsubishi Master
  • 8,617 Answers
If the model is a WS-65809 that sey doesnt come apart. Actually very few rear projection TVs can be seperated Some RCA TVs can be disassembled to several pieces. Also I would let customer know that because a CRT TV has three CRTs that are aligned to each other , Moving the TV will cause the convergence to be adjusted. Based on model it can be just pressing the auto convergence option with the remote, But older rear projection TVs (2003 and older) have been known to blow ICs after a move when trying to reset the convergence. The ICs weaken over age and they can blow anytime the convergence adjustment feature is used, so its always a good thing to let someone know that even if very careful when being moved there set may develop convergence issues after a move because its a 3 CRT rear projection TV
Posted on Sep 15, 2011
SOURCE:
I have a 2 year old Mitsubishi WD-73732 - 1080p 73" Medallion Series DLP HDTV - WD73732. I am getting blotches of color when there are large areas of blue color. Looks like irregular moving stains...
It will cost you probably in the area of $700.00 to replace the Light Engine. I don't think it would be a good idea to repair it. DLP sets have been out of production a few years now due to high failure rates of the light engines for all makes and models and the consumer cost for the lamp.
Nov 10, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Mitsubishi Medallion HDTV Integrated 1080 WS-65615 and the speakers wont work. I've tried the the whole speaker/audio stuff but it wont let me select tv speakers.... help please!
hummm if i may suggest something... do you have net command enabled this would disable the speaker selection giving control of audio to other devices.
Oct 15, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Nov 17, 2009 | Televison & Video
Is there any way to split the tv in two pieces for
I do not see any way to divide main wooden box of TV as you can remove front screen and back cover of TV but main cabinet of TV still remain the same.
Check below exploded views of WS-65313 for better explanation.
Thanks.
Oct 30, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Need to know if TV can be separted into 2 pieces
Yes it can and does come apart in 2 fairly equal sized pieces. There are some screws on the sides when removed the top half with the mirror will lift off. It may require some extra force the first time it is done but comes apart with ease after that
Feb 25, 2009 | Mitsubishi WS-65411 65" Rear Projection...
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
Mitsubishi 50705
Good Day, tree64;
More than likely the convergence problem the TV has wont be resolved by adjustments. In your situation, moving TV, the problem most likely is poor solder connections on the convergence IC's. They are large devices attached to very large heat-sinks, and have numbers on the IC'c like STK 392-560.
If no poor connections....replce.
Good Luck, big IRISH.
Jul 04, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Relocating tv
Yes, this set does come apart for moving. Remove the lower screw from each side of the TV back. On both sides, pull off the two plastic caps and remove the two exposed screw. Lift the cabinet top straight up until the guide pins clear the holes in the bottom cabinet. Be careful and don't drop anything.
May 03, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
207 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
