Hi. I have a DLP model # WD-65731 and cannot locate my owners manual. I'm looking for instructions on how to change the bulb and housing for the projection bulb. Cannot locate an on line manual...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. .
Mitsubishi is currently offering the following parts
Model Number
Model Description
Part Number
Part Description
Price
Available
WD-52631
52" DLP TV
I/B WD52631
OWNERS GUIDE
$15.00
YES
WD-52631
52" DLP TV
I/QR WD52631
QUICK/REF WD52631/57731/65731 'G'
$3.50
YES
WD-52631
52" DLP TV
915P049010
LAMP (150W) (V33/V33Y/V33+) 'G'
$249.00
YES
WD-52631
52" DLP TV
290P137010
REMOTE 'G'
$33.10
YES
Instructions on how to change a headlamp bulb are on page 5-56 in the 2003 Pontiac Bonneville Owner's Manual. If you do not have an Owner's Manual, you can download a PDF version at the link below (direct link) 2003 Pontiac Owner's Manual
It may be. I have replaced the lamp in my sony 3 times. Look for dlp lamps online and enter in your tv model. There are instructions online on how to change it yourself. They also show you in your manual. The power light should blink red indicating bulb failure. Read your manual. Hope that helps
the problem is likely the projection lamp .. you can replace that yourself if you are handy .. you must unplug the set and make sure everything is cool ...avoid getting finger prints on the new lamp ...here are a few places where you can get a new lamp ... you can also see what it looks like on this site ...
......it costs more mounted but its easier to change and you will need a new cage if yours is damaged .. from the site above you can see what the cage looks like with the lamp already mounted ..
your lamp is a model 915p049010 ... that is available thru amazon at a good price here:.(includes cage)........
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
the buzzing noise you are hearing is from the lamp ballast as it strikes the lamp. that is quite normal but it should only be momentary. it should not be constant.
