2000 Triumph Sprint RS Logo
neil Posted on Jun 18, 2017
2000 Triumph Sprint RS idles high
I have just bought a sprint rs with 27k on the clock. Runs fine but revs to high when you throttle off e.g. 2,200 revs when you pull the clutch in. If I select neutral, the revs drop down but once any gear is engaged and I move off I am back to 2,200 revs as a minimum. I have taken the aftermarket end can off and put the factory original back on but this has not helped. As you can imagine this makes the bike a pig to control in traffic. Can anybody help?
5 Related Answers
Anonymous
  • 2336 Answers
  • Posted on Nov 10, 2008
SOURCE: stuck in gear
ry useing blue LOCTITE on the pinch bolts and other fasteners to keep the shifter from vibrating loose again. I had the shift linkage vibrate loose on my Thruxton when it was new, I had to fix it on the road to get home.
Anonymous
  • 5 Answers
  • Posted on Jul 25, 2009
SOURCE: have a 2002 triumph sprint st 955i, bike would
Hi, the problem lays with your side stand switch. This is designed to stop us riding off with the stand down. When the switch plays up the safety still works with the stand up. Try giving it a good clean and spray with WD40. It gets covered in crud from the chain lube.
Tom
ROB
  • 858 Answers
  • Posted on Jul 28, 2009
SOURCE: clutch will not engage on trident 900
check that the actuator is releasing at the gearbox end!
as it could be loose or the shaft is binding up!
otherwise clutch needs stripping down & inspecting thrusts & friction plated for wear & burn marks[heat blueing] & that the metal plates are not warped!
also the pressure plate speings ma be week & all not equal tension
Cheers rob.
Anonymous
  • 11 Answers
  • Posted on Sep 27, 2009
SOURCE: motor cuts out when gear engaged
Make sure you have your stand up before you put it in gear. Some bikes have a stand switch that doesnt allow the bike to be in gear while the stand is down. This switch may have been damaged when the bike fell and now be malfunctioning.
Testimonial: "THANK YOU MR BEETHAM!!Ignorance can be bliss but it can also be bloody annoying!You have saved me from a sleepless night-so simple,will never forget!"
DoubleClutch
Greg O'Day
  • 376 Answers
  • Posted on Sep 30, 2009
SOURCE: 2008 triumph daytona
The switch for your kickstand mybe disconected. Or do you have the kickstand down.
2011 Triumph Sprint GT high idle
Hey Graham..
Have you had it tuned up lately...if you had the valves adjusted, the intake valves are too tight...if no one has been adjusting your valves.. you might have an air leak..??
Does the engine rpm's "kinda float" around for a few seconds..idling high then settle back to normal..? .. YES. then its a classic symptoms of too tight intake valves.
My 2003 sprint rs doesn't hold revs when starting, i have to hold throttle for a few minutes? choke issue? thanks
Your Sprint has no choke as its injected and fuel is controlled by the ECM. So this said there are a few possible things to check.
1 TPS throttle position sensor voltage.
2 Barametric pressure sensor (MAP)
3 Do you use fuel containing ethanol, injected bikes hate the stuff, makes them hard to start.
Number 3 is an easy thing to try, 1 and 2 you will need to look at the ECM with a computer. Its very easy and the cable to connect to your laptop is about $14. OBD2 to USB cable.
Have a 2000 Sprint rs won't start have spark change fuel pump an stepper motor cps sensor has 564 ohms changed computer saloon
Two things fixed mine first a new battery, the Sprint needs a really good charged battery to start, not just an old charged battery. Even jump starting didn't work for me. Second non ethanol fuel, these engines hate ethanol.
3helpful
Runs ok over heats and bubles up in the exspansion tank
drain and flush the coolant, use a non silicate type, change the thermostat...purge all the air from the system.
I have a 2004 triumph rs sprint 900 and washing it today one of the indicator stems broke and finding it hard to get a replacement one thaught about LED'S are there problems doing this i've seen...
Mate not really an answer but my 2002 triumph datytona, has got LED's on the front and i have no problems with them and have you tried Ebay for replacment ones.
My rs surges at lower rpms
Hi
Could be many things from spark plugs to dirt in carbs (If not fuel injected) to Air leak.
I NEED DIAGRAM OF VACUUM SYSTEM TRIUMPH SPRINT RS 2000
http://www.nirvana-motorcycles.com/Triumph%20Sprint%20ST%20RS%20955%20Service%20Manual%201999.pdf
2helpful
Couple of questions from a new RS owner
#1 As these are an injected bike they do not need to be blipped on start as it reprograms the ECU to think that the slight blip setting is the normal closed according to the computer. You may need to get it reset at your dealer unless you have an OBDII or a Triumph GameBoy. #2 Change out the oil to a semi synth. Your choice on brands. I'm not starting You'll find that it will improve the shifting as they aren't the smoothest with old oil. I use Motul 15-40 semi synth myself FWIW I change mine every 5000 kilometres (about 6 months) but go on k's travelled and not duration myself.
Top Triumph Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Triumph Expert? Answer questions, earn points and help others
