SOURCE: Engenius EOC-3220+
if you have a the router's manual,there is a guide on how to do that.
but in case you dont have the manual go to the device website and get some guide.default ip varied from different manufacturer
SOURCE: how do i reset my Engenius EOC-3220
This might be helpful
http://www.fixya.com/support/t629167-getting_setup_pages
SOURCE: resetting EnGenius EOC 3610
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3610.
b. Select correct COM port. Ex:COM1.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
SOURCE: how do i reset my engenius senao eoc 3220 outdoor
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
SOURCE: how to extend lan with engenius
This is a lengthy topic. Full instructions answering exactly this question can be found here:
EnGenius 2610 / 1650 bridge router configuration
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
