Did you try setting the color printing in printer properties.
If you have XP;
Open 'Printers and faxes'.
Right-click your printer and select 'Properties'.
Click 'Advanced' tab.
Click 'Printing Defaults' button close to bottom.
Select 'Paper/Quality' tab.
Select 'Color' option.
Click OK until all dialog boxes are closed.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the
print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\
folder. You should see files there ending in .SPL and .SHD created around the
time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the
Try to print a document again to verify that the problem is fixed.
Lexmark recognizes that some of our inkjet all-in-one customers
may be experiencing issues with their print quality. We take our
customer user experience very seriously, and we strive to ensure that each time
a customer prints using a Lexmark device the page is crisp, clear and up to the
highest standards.
However, if your device is displaying a 'printhead error' on the hardware and/or you are suddenly experiencing a print quality issue, please contact the Lexmark Technical Support Center at 1-800-539-6275 or point your browser to http://bit.ly/lFKDzs for online technical assistance.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color. And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
