Question about Mitsubishi WD-73734 73" Television
White dots on my mitsubishi WD-73734 tv screen
  • Mitsubishi Master
  • 11,800 Answers
Your tv is a DLP projection one. In it the image is generated by projecting light on a chip that is covered in tiny mirrors that reflect more or less the light towards the screen. In your case some of those tiny mirrors are no longer controlled - they are immobile and reflect fully the light so you get a white spot on the screen.
The DMD chip that holds the mirrors is dying and you will have to replace it. This is the only place i could find that claims to have it on stock. You can also go thru Ebay, in there you will find second-hand ones extracted from defective tv's.
It's installation is strictly a job for a person with great tv repair experience - too many thins can go wrong in there if the job is not done properly.
Posted on Sep 15, 2011
2 Suggested Answers
SOURCE:
igop_oka29
  • 317 Answers
SOURCE: My 73734 mitsubishi tv has
Try to re align the antenna of your t.v but if nothings happen Try to contact a t.v technician maybe your t.v has a problem with the picture tube
Posted on Jul 01, 2011
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
My Mitsubishi WD-73737 73 in TV has white dots taking over the screen
Bad DMD chip
call Mitsubishi, they will send one to a servicer at no cost, you will only pay for labor
Sep 19, 2014 | Mitsubishi Televison & Video
White spots on my screen
Seems like a dead pixel in the display. The only way to fix it is to buy a new screen which could be more than the TV itself or just buy a new tv.
Dec 30, 2012 | Mitsubishi WD-73734 73" Television
Mitsubishi DLP TV wd-73734 HAS WHITE SPOTS
Bad optical light engine, most expensive part in set
Dec 09, 2012 | Mitsubishi WD-65733 65" HDTV
Have a 73" mitsubishi model No.WD 73734 and I have
On the TV not the remote, simultaniously press the menu and input button for at least 5 seconds. This should give an error code. If it blinks 3 times then a pause then blinks 2 times, the code would be 32. Get your error code and look in the service book at: http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf -
Sep 22, 2011 | Mitsubishi WD-73734 73" Television
Getting more white dots daily. I'm told it's the DLP chip. I have model WD73734 . Can't seem to find anywhere to buy a new chip. Any suggestions?
http://www.ebay.com/itm/DLP-Chip-Mitsubishi-Samsung-4719-001997-1910-6143W-/160648889279?pt=LH_DefaultDomain_0&hash=item25676b83bf
Sep 08, 2011 | Mitsubishi WD-73734 73" Television
My 73734 mitsubishi tv has white dots all over the screen
Jul 01, 2011 | Mitsubishi Televison & Video
I have little white dots showing up on my screen the size of pin holes. I just replaced the bulb 2 months ago.
You need a new dlp chip. The tiny Micro mirrors inside of it are getting stuck and there is no way of freeing them. You can either buy a new light engine which is very expensive or buy a new DLP chip and change it yourself. It takes about 30 minutes to do and is very easy. I have the DLP chip for $225 new. Other places will charge you about $345. tharizen@yahoo.com
Feb 02, 2011 | Mitsubishi WD-73734 73" Television
White dots are showing up on the screen. They are multiplying quickly. I was told to clean the filter but that did not help. The lamp is less than a year old. Nearest dealer is 2 states away. How can this...
This problems is the tv Projection Light Engine design flaw with it IC chip.These problems happen to many models of it DLP tvs Big Screen 60 and up.Mitsubishi,Samsung,Sony,Toshiba all used the same IC chip on their 60 and up on their DLP tvs Big Screen.Tries make deal with Mitsubishi help u split the cost of repair the tv Projection Light Engine by replacing the IC chip or replaced the entire Projection Light Engine system.This problems is not new,been going on for a few years.Many people when on Youtube **** about this problems with white dots showing up on their tvs screens and multiplying rapidly.
Nov 20, 2010 | Mitsubishi WD-73734 73" Television
White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Mar 05, 2010 | Mitsubishi WD-73734 73" Television
Mitsubishi WD-73734 73" Television Logo
460 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
