When pushing the bake or the broil to turn on it comes up E1 F1 . I do not know what this means and i can not find manual. It is a kenmore glass top oven and is about 10yrs old. Not sure if these have fuses in them or where. Cleaned oven and only worked once after. Can you help me with this problem?
How do you reprogram oven, when it gives you an F1 error. Top broiler will not cut off, I've unplugged the stove for about 3 min and plugged it back in and the top broiler still came on. Still have stove turned off.
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
