Hello The unit has 2 alarms (alarm 1 and 2). They can be used together or independently. Alarms 1 and 2 have different sounds so that you can differentiate them. The alarm will To set the alarm: Navigate to "Set Alarm" setting mode as shown in the Changing Settings section. The order of the settings is; To enable or disable the alarm: • Press MENU until you reach alarm 1 or 2 display. • Press [UP] or [DOWN] button to enable or disable the
sound for 1 minute unless it is disabled.
alarm 1 or 2, hour and minute.
alarm. "-:--" means disabled.
OK.
Travel alarm clocks can have varying
instructions, depending on the type of clock you are using. Here are
some tips for use that will apply to any alarm clock.
