hi master reset codes help you to reset your mobile .once you reset your mobile you can set another codes .to get the codes visit theunlockspot here they ask the phone model and the imei number of your mobile .finally they send the codes to reset your mobile.
If you go to micromark web page all the instructions are there, but any way press *1122# press *1 # to go into password programming mode enter 4 digit password and #, press * 0 # to exit programming mode. All done.
Dipo
Hi have micromark electronic safe no EX2003085561 when i enter code top right hand green light flashes and lock will not open any assistance gratefully accepted
Stewart
if it's in a cold room use a portable room heater for a few hours to raise the battery tempreture a few degrees this may give them a boost, then try the factory preset code 159A or 159B
code of micromark mm23084
Press 1122 to keep device in normal
Press P1122E to enter Programming mode. Press PIE.
Enter your new 4 digit code, then press E (ie., ????E)
Press POE to exist programming mode
hi u do onething, u remove ur battery and then refix then switch on ur mobile, u press menu button before its go to lock, then if u can u change ur password or u will do factory resetting. before u take back up ur contact and all...
this is your 10 digit master code.. keep is safe because this cant be changed, only security code can be changed. this code will work everywhr whr it asks for SECURITY CODE (ex keypad unlock with security code, reset phone to factory settings, etc.)
