Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
Posted on Dec 23, 2017
Describe your LiteLine 6100 (B9961001002) Modem Problem I have a Westell 6100 and want to know what I need to hook up a ROKU (I Have not purchased yet.) The 6100 has all lights lit except USB. I am 83 and don't have the instincts of a younger person, but I know how to follow instructions that I understand.
3 Related Answers
Panth3on
Michael Robinson
  • 71 Answers
  • Posted on Sep 14, 2007
SOURCE: Connect 2 PCs to Westell 6100 DSL modem
well depends on if you want to hookup wirelessly with one or not. If the modem has a USB connection as well as ethernet, then you can hook up 1 computer to usb and 1 to ethernet with no problems. If you do want a wireless hookup then yes, you need a wireless router. I would just go with a router because of the convenience of being able to go wireless if you decide to. I would suggest a Linksys WRT-54GL with a 3rd party firmware (DD,-WRT, Tomato, etc.) Hope this helps.
Anonymous
  • Posted on Jul 11, 2008
SOURCE: westell 6100 problems
we had the same issue. Here is how we fixed it. I had the xbox 360 plugged directly into the westell 6100 modem via ethernet cable. the mtu test failed everytime. I was extremely frustrated and called microsoft and verizon (dsl) about 10 times each and they kept giving me the wrong solution. (get a new modem, get a new server, pay us money and we'll figure it out etc...) Here is what a man at microsoft told me to do and finally it worked. Power cycle your equipment (unplug modem and xbox 360 for 30 sec.) then, plug in modem first and wait until all lights are back on. Then plug in xbox and run test. In my case mtu failed again. I was then instructed to go to my dashboard and restore xbox to factory default which I did and rerun the test. This time everything FINALLY passed. We were in business. I then decided to try connecting through my airport extreme router. I power cycled again starting with the airport then the modem then the xbox and ran the test and unbelievable as it sounds it all passed and my son is now sitting happily on the couch playing a game online with his xbox 360. This took away days of my life to get this simple thing done. I was given codes to change and change back on the computer, phone calls to everyone and the solution was so simple when you finally reach a knowledgeable person. Hope this will help save someone else the time I spent!
A
Anonymous
  • Posted on Aug 02, 2008
SOURCE: Westell 6100 network cable
I cant find the gui address to the westell wirespeed e90-610030-06 ?????
Westell 6100 manual Rev R manual available?
http://www.google.co.ma/url?sa=t&rct=j&q=westell%206100%20manual%20filetype%3Apdf&source=web&cd=4&ved=0CDYQFjAD&url=http%3A%2F%2Fwww.westell.com%2Fdocs%2Fsupport-documents%2Fwestell_prolineg90_userguide3D214D374C48.pdf%3FStatus%3DMaster&ei=tFXETtfwLYe28QPW3uywCw&usg=AFQjCNFBjA31h8DNWEuubd9_WWF5vfyatA&sig2=5xF0buxf9K9YbLu51gRJCg&cad=rja
Do the dsl modem have to be connected to an isp before the ethernet light comes on. i started service with att and i have a modem westell 6100 i purchased before from them and i still have the software but...
no. The ethernet light should comes on right away when you plug modem if there is something plug in. There is a but. But if your dsl light is still flashing and not staying solid it is your isp problem.
1helpful
My Westell 6100 F modem beeps
It is having trouble with the cam settings with your modem. You need to contact Verizon and they should get you line out.
I have a westell 6100 and I have a linksys wireless-g 2.4 ghz broadband router. Not sure how to hook the router to the 6100
just set it up as a passive style and do not let it log on to your isp it should default to this setting if you plug it up and do not run the setup software
Westell model 6100f modem
My ethernet light On my 6100 westell is not on what are the causes. The light use to be on Thanks
Westell 6100 modem not working for internet access
Unhooking the modem didn't jaz things up it was when the computer was repaired. You have to run the installation disk again or just buy a mac.
1helpful
2answers
Driver
not true...i have this exact modem, and it is not plug & play, im searching for the usb driver myself and having no luck
Westell 6100
This is due to a modem failure. You will need to replace the modem.
Top Westell Wirespeed Computers & Internet Experts
Sean Wright
Sean Wright
deton8 von Splosion
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
