Anonymous Posted on Sep 14, 2011
Need manual for a Rotel dvd player RDV -1092 - Audio Players & Recorders
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Sep 14, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2765884
Points
24828
E76-LE2-2/45 TK-1 transformer data sheet
Service manual says it has already selectable voltage transformer in it having selection of 120V, 220V and 240VAC. Anyway see page 9 of service manual
ROTEL RX-855 Service Manual download, schematics, eeprom, repair info for electronics experts (elektrotanya.com)
2answers
ROTEL RCD-951 TM can not open tray.
Hello Ruben, so you do not open the CD holder tray of your Rotel, the problem is that the belt that transmits the rotation of the engine to the mechanism of the car, may be stretched and therefore the car does not open, this is the most common fault in this type of CD players
You should replace it, if you can not do it, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Ruben, por lo que cuentas, no se abre la bandeja porta CD de tu Rotel, el problema es que la correa que trasmite el giro del motor al mecanismo del carro, puede estar estirada y por lo tanto el carro no se abre, esta es la falla mas habitual en este tipo de reproductores de CD
Deber?s reemplazarla, si no puedes hacerlo, busca un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://elektrotanya.com/rotel_rcd-951-tm.pdf/download.html
http://bwgroupsupport.com/downloads/manuals/rotel/RCD-951-OM.pdf
2answers
I have an rdv 1060 which will not play dvd's cd's are finecan u assist
Unfortunately, the DVD laser diode is probably faulty. a separate laser diode is used for reading CDs so these still work. The laser unit will require replacing.
2answers
Rotel dvd player not reading dvd but will read cd
if it doesnt read any kind of dvd discs at all it only means you have been rip off. It happened to my sony dvd player that I bought from this website. I tested it and it only reads cd or audio cd. Good thing my couzin fixes electronics, He checked on the lens and it turned out that the lens has been replaced with an audio/cd lens like the one we use for our car stereo. Too bad!!!
Bubble console codes for eltax dvd player
the codes are 0766 1092 1096 1319 1320 1321 1987
 Grubhead
Grubhead
SmartAviator
SmartAviator
