You can format the CF card to overcome this problem.
Select 'Format' from Edit menu.
Push and hold the 'Shift' button and push the Menu button. 'Trk Erase' will appear. Push the >> (Double arrow) key until you get 'Format' on the screen.
Press 'Enter' and when it asks 'OK?', press Enter again. Screen will display 'Executing' and finally 'Completed'.
Push the 'Stop' after that.
NOTE: Deleting Tracks/Files will not reset track counter.
Since you have reached the 999 track limit, it is possible your CF card may have been corrupted.
On page 28 of your manual you should find the instructions for formatting your CF card.
"How to Format a CF Card."
This may get you going again.
Hope this helps.
Thanks for your help Brian, I've found that if I delete the most recent tracks then it lets me record, but I always thought it would be able to go back and fill in the blanks (of which there are 500+!). I'm still able to access the files via USB and transfer them across. Does this info shed any further light on the situation?
That still sounds like a badly formatted or corrupted CF card Joe.
You could try moving your 500 files first to your PC to backup the card,
then format the card using the Marantz device itself, not the PC.
Then copy all the files back again to a nice cleanly formatted card the way the Marantz likes it.
You never know.
Brian.
