SOURCE: I have a Maytag Jetclean Dishwsher EQ Plus, Model
I have the same issue. I need to put full weight on door to get the dishwasher to go. The tongue (on the top of inside) is fine. The problem is in the latch. Looks like I need to take the door apart and get a new latch. I am guessing you have to remove the 8 (?) allen screws on the inside of the door and take a look. Good luck. I will tell you how I do. Post back if you have it figured out.
SOURCE: Maytag Jetclean Dishwasher EQ Plus, Model
You have debris down in the pump area. To get to the problem you will work from inside the dish washer and start by removing the spray arm and then using torx driver you will need to remove upper components of the pump/motro assembly to get to the debris. good luck
