SOURCE: HI I HAVE ONE MOTOROLA SYMBOL
The EMEI Barcode and battery barcode are probably not the same length. When the scanner is set for specific length, he will accept only some barcodes.
Please check the length of the barcode.
Set the scanner for two specific lengths or for any length of barcode.
Try to scan again.
To set the scanner you would need programming barcodes. Those are listed in the DS6707 Reference Guide, provided at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=8397807apdf
SOURCE: Symbol barcode scanner LS4071 + base RL475
Hi, you will need the 25-17821-20 and STI80-0200R cables to connect to PS/2. You must have a PS/2 keyboard for this connection.
If you would prefer to connect to a USB port you should get the 25-17821-20 cable with the STI85-0200R.
The RL-475 was for the IBM, but it also supported Synapse which is the STI cable.
SOURCE: Barcode line enter problem
This is a custom setting. You will find on the user manual (and also at the bottom of the Quick Start guide) a special barcode that, when scanned, toggles between "CR after barcode" and "No CR after barcode".
SOURCE: is the ds6707 compatable with windows 7?
If connected with a CBA-U01-S07ZAR and programmed as the default HID keyboard USB host type, yes it should be compatible. The device uses the same drivers the host uses for a USB keyboard.
SOURCE: How to install Mc9090-k driver??
Have you looked at the manual?
Symbol MC9090K Manuals
Drivers may be here:
portal motorolasolutions com
