I dropped my Razor V3 in water. The phone works fine including the outer display screen. The flip (main) screen is blank but illuminated. Is there a fix for this problem?
hi :)
motorola K1 is a flip phone,when open flip no display,that mean phone ribbon was spoil.pls send for mobile technician to change a new ribbon.
pro will solve.
Sounds like the phone is defective..Contact your cell phone provider to see if they are willing to replace it for you...I believe most company gives you one year warranty for the phone...
Hope that helps
Please rate accordingly
Thank you
COmputerrep
is it a blank screen, if it is, the problem with your phone is that the flex on the screen of your phone is weak or damage, that is why your screen did not display.
All you need to do is to replace the flex on the screen of your phone and you will see that your phone screen will display. Change the flex on the screen of your phone as advice and you will see that your phone screen will display.
Since it is a flip phone i guess your flex is damaged or your screen is faulty.You need to first change the flex or check whether the cord is well connected.
If u have a Razor (As shown in the picture), If the mini Screen Works(When you close the phone) then then make sure the push down button((Turns off the main screen when you flip the phone closed) is not pushed down while the phone is open.
Sounds like water damage. Are there any red stickers under the battery? If so, then it is water damaged.
Either way, if you are the primary line then Verizon may offer you an early upgrade if your rateplan is above a certain price point (if that's who your on). If not, you can do an insurance claim, if you don't have insurance then you will have to either pay full price for a new one, or purchased a used one.
Be very carefull with the phone. The main cable runs through that left side.
Look on Ebay for a Left hinge pin for the V3. Also knows as the left knuckle.
Make sure you look for the V3. Not Razr.
If your speaker goes out, or you lose display before you get the Knuckle, you need to get a keypad flex also.
If not, get the Knuckle, and it just slides in. MAKE SURE before you pop it in that there are no pieces of the old one in there and that you don't pinch that cable.
I can fix it for you if you send it to our business, but if you're careful, you shouldn't have a problem.
yep i have the same problem too. no date display. it displays the date on the outer screen when i flip the phone shut. but not on the main screen when it is open.
