Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Posted on Sep 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our Konica bizhub 350 won't scan more than 3 pages. Our server is Windows Server 2008 R2 Enterprise. I've been told there is no appropriate driver that will make our photocopier scan properly. Is this true?
M V Tech
Level 2:
New Friend:
  • Expert 149 Answers
  • Posted on Oct 11, 2011
M V Tech
Expert
Level 2:
New Friend:
Answers
149
Questions
Helped
19711
Points
229
Try this settings.. it work fine at my office (XP & win98)..
setup guide (pdf format)
There is no twain-compliant device installed m1136 mfp scanner drivers not installed on server 2008 r2
It may just not be supported on that OS. Try another OS's drivers and see if it works.
Konica minolta bizhub pro 920 won't scan to email
have you log in to the copier via page scope and properly set up the scan to email info required, such port, mail server, authenication procedures
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Bizhub won't scan to SMB share on Server 2008
Mite want o check the IP address there where more than likely set as static. Can the copier be pinged? Also ensure all the folder s at stilled shared.
Hi, Our Konica Minolta printer c203 with reserved dynamic ip address in dhcp (windows server 2008 r2) won't print. Should I assign a static ip address? Kevin
it will be easier to set the copier up with a static ip. then the server can find it easier. to do this go into admin mode and change it.
I have an Ml 110 G5 Server, But i could not find the VGA driver for the Win Xp , kindly assist thanks Justin
Hi, I m really sorry to say that but you have a Server Product and its built to run Windows Server Series on it (or Linux / Novell Netware).
This is the list of compatible Server list
Microsoft Windows Server 2003 Microsoft Windows Server 2003 for 64-bit Extended Systems Microsoft Windows Server 2008 Essential Business Microsoft Windows Server 2008 Foundation Edition Microsoft Windows Server 2008 R2 Microsoft Windows Server 2008 Small Business Microsoft Windows Server 2008 W32 Microsoft Windows Server 2008 x64 Novell NetWare 6.5 Red Hat Enterprise Linux 4 (AMD64/EM64T) Red Hat Enterprise Linux 4 (x86) Red Hat Enterprise Linux 5 Server (x86) Red Hat Enterprise Linux 5 Server (x86-64) SUSE Linux Enterprise Server 10 (AMD64/EM64T) SUSE Linux Enterprise Server 10 (x86) SUSE Linux Enterprise Server 9 (AMD64/EM64T) SUSE Linux Enterprise Server 9 (x86)
Here is the link for Drivers
Try to use the Driver for Windows 2003.
It has a Matrox VGA as I know. If you know which Matrox series you have, then Browse here for the Drives: Matrox Graphics Support. Make sure that you choose the Exact Driver software which suites the System.
Note: Not every product has the Driver Software for Windows XP.
Please rate the answer! Thanks for contacting Fixya!
I have tried x2 chassis and working memory but cannot get the full 12gb installed and runniing with Win 2008R2. it only takes x4 2GB sticks. Have tested all sticks in other machines and in same one...
Please see the below table to find you are on the right track.
Windows Server 2008 R2 Datacenter 2 TB
Windows Server 2008 R2 Enterprise 2 TB
Windows Server 2008 R2 for Itanium-Based Systems 2 TB
Windows Server 2008 R2 Foundation 8 GB
Windows Server 2008 R2 Standard 32 GB
Windows HPC Server 2008 R2 128 GB
Windows Web Server 2008 R2 32 GB
HI , i have the problem with my Scan to PC to scan the File to my Server , i have runing the Active directory on my server , i have made an administratoor account with full access on my my share folder on...
this would be on a domain then
1 open the default domain controler security setting
2 local policies
3 under security setting for microsoft network server set: digitally sign communications from always to disable
so with digital sign on the server the scan jobs are not digitally signed and will be rejected by the server.
or you could set it up to scan ftp or email if you have either one of those type of servers in the buiding they cant be external servers
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
