Twitter Tweets Logo
Anonymous Posted on Sep 15, 2008
Twitter Error Message
I keep getting this error message from Twitter -
Sorry, you have reached your following limit for now.
What is the reason I receive this error message? How can I solve it?
Justin Losh
Level 2:
  • Expert 36 Answers
  • Posted on Mar 21, 2009
Justin Losh
Expert
Level 2:
Answers
36
Questions
0
Helped
19908
Points
101
Twitter limit's how many people you can follow at a certain time, to help limit spam accounts. You may be able to contact Twitter Support or wait a day or two and see if it changes.
Twitter Support: http://help.twitter.com/requests/portal/new
-You will have to login with your Twitter username and password, then you might have to open the url again.
Hope this helps!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2357
Points
I have tried to join twitter and can't seem to get it done. I keep getting error messages and have never been able to join.
Bess Manar
1helpful
If someone tweets, how do u reply to that particulat tweet?
The largest pic size for twitter is 700k, and they support JPG, GIF, and PNG formats. The photo will be reduced to 78 pixels square for your main page, and 48 pixels square for use in the timeline.
There are two ways to reply/tweet to people directly, 'private' and 'private-plus-friends':
  1. Type "d USERNAME" before your tweet to send a direct message to a particular user. Only that user will see the message.
  2. Put "@USERNAME" at the beginning of your tweet to send a reply to a particular user. That user, your followers and that user's followers will all be able to see the tweet, but it won't appear on the public timeline.
You may receive error messages with the whale picture, but this is generally uncommon.
I hope that helps.
___________________________________
Twitter Over Capacity Error Explanation
tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 • Computers & Internet
2answers
How do you tweet
There are two ways to tweet people directly, 'private' and 'private-plus-friends':
  1. Log in to Twitter via the Twitter Home Page, or via API. You can also update Twitter via Facebook and several other applications that use the Twitter API.
  2. Enter your message in the box with the label "What are you doing?" Keep in mind that your tweet can be no longer than 140 characters at the most. This limitation exists because Twitter uses the SMS network to send notifications via cell phone to those who desire it.
I hope that helps.
May i ask about twitter if i reply someone on his tweets did he read or received my message even though he is not following me.?help me on this tnx
Provided you don't get stuck with the Twitter Is Over Capacity Whale that I've been seeing lately, there are two ways to reply/tweet to people directly, 'private' and 'private-plus-friends':
When you send that message with D or @, then the user will get our message even if you are not being followed.
I hope that helps.
1helpful
I cant figure out how to ask questions or comment on someones twitter page. so how do i ask questions?
Provided you don't get stuck with the Twitter Is Over Capacity Whale that I've been seeing lately, there are two ways to ask questions of people directly, 'private' and 'private-plus-friends':
When you send that message with D or @, then the user will get your question even if you are not being followed.
I hope that helps.
How do I tweet a question to a person on twitter?
  1. Log in to Twitter via the Twitter Home Page, or via a Twitter API application such as Twhirl. You can also update Twitter via Facebook and several other applications that use the Twitter API.
  2. Step 2 Enter your message in the box with the label "What are you doing?" Keep in mind that your tweet can be no longer than 140 characters at the most. This limitation exists because Twitter uses the SMS network to send notifications via cell phone to those who desire it.
  3. Step 3 Click "Update" to send the Tweet to everyone on Twitter.
  4. Step 4 Type "d USERNAME" before your tweet to send a direct message to a particular user. Only that user will see the message.
  5. Step 5 Put "@USERNAME" at the beginning of your tweet to send a reply to a particular user. That user, your followers and that user's followers will all be able to see the tweet, but it won't appear on the public timeline.
4helpful
2answers
Error message on htc hero message size limit reached sorry you cannot attach this to your message
I believe there is a size limit of 512k for attachments. Phones are just not designed to attach huge files to text messages etc..
Can't access anything on Nokia 6300. It locked up and gives message of: (Message storage memory not ready) No Nokia place around to take it to. Please help!
The phone's memory is full, which causes the error message and lock ups. This error prevents you from freeing up memory by deleting messages.
Try the following (taken from the Nokia support forum): http://discussions.nokia.co.uk/discussions/board/message?board.id=hardware&thread.id=7775
1. Delete unused names/numbers from the address book to free up memory. (Perhaps write down the ones you want to keep for later re-entry)
2. Once a critical threshold is reached the msg inbox indicator will blink on
3. Enter inbox and DELETE as many messages as you can before phone freezes up again
4. If phone freezes or you get the error message again, restart and keep deleting from the phone book until it allows you hassle-free msg inbox access as per normal (but don't forget to continue deleting thos messages).
Top Twitter Computers & Internet Experts
 Grubhead
Grubhead
john h
Are you a Twitter Computer and Internet Expert? Answer questions, earn points and help others
