Hello there, usually replacing fuses are not the solution to most problems. Basically what you have to do is first locate the source of power to the fuse and identify why the power supply to the fuse is as high as it is and address the reason for such flow before replacing the fuse. Depending on what happened to cause the problem initially you might have to replace more than a fuse and probably a diode and a conductor which supply power to the fuse as they might have lost the ability to step down the power which flows to the fuse. Check the components which supply the fuse to determine where exactly the surge in power is coming from.
Hope this support has been helpful?
Thank you for visiting FixYa.
