Error (5800) My Cannon PXIMA MP130 kept showing the message "Check Printer Error (5800)" even after I have cleaned the waste ink reservoir on the right side of the printer. Suggestions given for the same problem on MP150 model did not work. Help me solve the problem as we have no cannon service center in Myanmar for printers. Percy
Turn on the printer (MP130) and do the following: 1. Press MENU SCAN COPY SCAN to enter service mode 2. Use > to go to NVRAM ACCESS 3. Set ABS-M LEVEL to 0 4. Set ABS-P LEVEL to 0 5. Press STOP to exit
Done, hope it work. I tried this suggestion by Mark and it work!!! Your suggestion did not work.Post to this threadPost a new message threadcanon mp130 (error 5800) by mark a (9/20/06 1:38 AM) reply+ / -
printert comes up with error code 5800 before intialising can anybody help please
Re: canon mp130 (error 5800) by arifinsukardi (9/20/06 1:59 AM) reply+ / -
Mark, you can try this:
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan 2) Enter NVRAM by presing <--- or ---> then OK 3)SET ABS-M LEVEL TO 0 4)OK1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan 2) Enter NVRAM by presing <--- or ---> then OK 3)SET ABS-M LEVEL TO 0 4)OK
You can't post conmments that contain an email address.
To reset waste ink counter: Press Menu-Scan-Copy-Scan to enter service menu. Use arrow keys to scroll to "Service menu counter access". Press OK. Use arrow keys to scroll to "ABS-M DOT COUNT" Press Copy. Use arrow keys to reset count to zero. Press OK. Press Stop/Reset.
OR
Reset for mp130 turn on the printer press menu press scan, copy, scan to enter service mode use> to get to nvram set ABS-M level to 0 Set ABS-P level to 0 Press stop to exit..........Done
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced) 2) Select TEST MODE. 3) Enter NVRAM ACCESS 4) Select SET ABS-M LEVEL TO 0 5) Select OK 6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
Two
possible ways to remove this error from your printer. First, is to clean
the absorber pads that are full of waste ink. Second, is to reset the
printer to clear the error and let the printer print again.
Clean the two absorber pads. Two absorber pads located on the right side of the printer, under
the ink cartridges when it is resting. 1. Turn on the printer. 2. Lift the top cover to
expose the ink cartridges. As soon as you lift up the cover the cartridge
carrier will move away from its home base.. Then the pads will be exposed. It
will be a dirty job so be prepared with your tweezer and extra cloth for some
ink spill. 3. Using the tweezer, lift up the pads sitting on a rubber retainer.
The pads can be easily clean by placing it under a running water. Warm water
will be nice to remove the ink from the pads. 4. After this, you can now return
the pads. However, the problem will not be solve especially if you are
currently facing the waste ink absorber full error or E-27.
Use a reset procedure to clear the error in your
printer 1.Turn
on the printer
2. Press
the MENU key
3. Press
SCAN button
4.Press
the COPY button 5.Press
the SCAN button then wait until it enters the service mode.
6.Select
NVRAM ACCESS further OK
7.Select SET ABS-M LEVEL and set value equal to
zero
8.Select SET ABS-R LEVEL (if any) and is set to
zero.
9.Turn off the printer Do this as many times if the first attempt
didn't work until it fully reset.
Hi: The problem here is the waste ink pads are full, these pads are located at the lock posistion to the far right where the units cartridge holder goes when you power down the unit and on start up. The way to solve this to to have the pads replaced, they are used to collect the waste ink the printer uses to clean itself when starting up, These pads usually take a long time to fill up, so either you do alot of printing or you hve used Non Canon inks or generic refill cartridges in the past, these are not good for your printer as some of these types of inks are either to thin or to thick and fill the pads up prematurely..Keep in mind to always use recommended guine ink cartridges you may save a little now with ink refill cartridges but in the long run your printer will eventually give out.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130. 1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced) 2) Select TEST MODE.
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Ink Absorber Replacement OptionsThis printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to release the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full. Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk the 5800 code. uplug cord from outlet. wait 1 full min, then plug in and let go through self test. reply for more help. have a great day and please rate bama46, thank you
Post to this thread Post a new message thread
Done, hope it work.
I posted that solution that worked on my printer. I found it on other site. I hope others will also be as successful as I am.
Percy
Thank you all... :) it;s works! :)
