Computers & Internet Logo
Posted on Sep 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our new hp monitor won't restart after computer is taken off sleep mode the screen will show a partial screen saver but it won't display icons until you turn off monitor and turn back on
Brian Sullivan
Level 3:
  • HP Master 27,725 Answers
  • Posted on Sep 13, 2011
Brian Sullivan
HP Master
Level 3:
Answers
27725
Questions
Helped
5669897
Points
79191
Is this only your monitor or is it your computer as well
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) Ide/Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
How do i get my hp w2007 monitior out of sleep mode
no PC stated or OS.
is this VGA, DVI or HDMI?
guess VGA. and its matching cable.
there are 2 sleeps, on old monitors.
the PC sleeps the monitor by disabling the 2 sync,. wires
HORZ and VERT,
the display shows, NO SIGNAL when this happens.
2008 (your monitor is 2008 , can be)
older monitors , have built in sleep, called also power saver TIMER. (push menu button on monitor)
read page 4-5 in your free HP manual.
PDF page 31.
http://h10032.www1.hp.com/ctg/Manual/c00834092
(aobut 1/2 do not have LED back lamps this year)
also this monitor has CCFL back lamps that by now
all go: most are dead now, used every day 8 hours per day.
1: dim
2: yellow
3: dead
4: or works 1 day , minute or week then not. (random)
if the pc tests ok on newer monitor, then its not the PC
if the Monitors fails on other PC , turn off power saver inside.
if the CCFL is dead, shin a flashlight on the screen, see data.?
if yes, the CCFL lamps are DEAD. (now or soon or whenever)
Dell Inspiron 530s Desktop fan motor keeps running
It\'s NOT the fan. Check the power save settings on the computer ITSELF. Check your BIOS settings as well. Inspirons ALL do the same thing with waking up.
Keyboard and mouse not working and monitor going to sleep
HP Pavilion Slimline S3400f Desktop.
dont worry ALL PC end up like this,, all do.. sooner or later..
NO OS stated, XP"? never post without OS stated, or answer get 10x more harder, See? make it easy for the helper and get more help.....
no Monitor stated. (maker, CRT, LCD what?)
The monitor is not fibbing to you BTW, the PC did go dead or to sleep. seems its monitor monitor of some kind with DVI.
if the monitor works on other PCs then the monitor is not bad.
i Bet it works (old ones 2002, have a hidden deep internal sleep mode. and is not yours IM sure now) DVI IS THE ONLY CLUE THERE.
So PC is dead. this PC came with only VISTA new,
is it still VISTA?????????
HP has support on it still
here (carbon dated by me 2008, IIRC)
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-slimline-s3400-desktop-pc-series/3688715/model/3688723
this year,? get all those files and books there backed up
when HP support ends after 10 year rule, (be savvy?)
what keyboard USB or wireless keyboard mouse
use wired USB keyboards if wireless the battery is dead. easy no?
now in VISTA, go to Control panel, click power
turn off all sleep modes and all hibernate modes
the turn off screen savers, if turned on , disktop . RC right click
in display settings or personalize, turn off , need login to come out of sleep or screen saver.
try a real keyboard, that has USB cable yet? be first thing to do.
always keep a real keyboard, handy,,,
batteries fail. in all wireless devices like this (inside them)
luck you desktops have lies DIM fails. there are many.
http://www.pcdied.com/sleep-or-dim.html
one other way , and common is PC overheated.
all do that.
ever one not cleaned out every year,.
#1 all time cause of overheat and PC shuts down.
http://www.pcdied.com/overheated.html
The monitor will go into sleep mode, and when first booted up will not register anything and goes to sleep. Have tried re-booting, checking the chords, plugging and unplugging them in. To no avail it...
No pc stated just monitor. (not even desktop or laptop) stated.
no OS stated, ether.
so ill answer in wide generic ways....
all computer are a problem, since days of Mr. Allen Turning to now.
ive done 43years of them just puters.(and other big systems MIL)
no person on earth can answer that common question
gee no pc stated,! nor can we lay blame until its fixed can we. ever.
3+billions of transistors. mine here typing now.
4,800,000,000, and friends, lots of other things to fail even LCD
its not a toaster or 4 banger calculator, at all.
its COMPLEX but 1 of those 2 boxs or cable are bad. sure.
(viewed in the MACRO)
sleep? how do you know it is sleep.
the screen showed that. text said SPEEP?
is the screen totally dead. (that is not sleep if true)
is the screens OSD button dead?,
the only clue i have here is one word, REGISTER (good word just too few)
so the screen never ever shows any text or HP logo ever
booting with monitor on for 5min. power on PC, see words?
no text ever...so.
then push the monitors.
Select menu buttons on front of monitors. and the OSD pops does it , it must....!!! see image below (mine is Viewsonic, near new)
there are many simple tests here.
  • try you monitor on any other PC
  • or try you pc on any other monitor
easy no.?, just 1 or 2 tests and bam, who's bad.
called the process of elimination..
but OSD is first. no matter what,.
if the screen tests ok,, (display tests and its buttons)
then the PC is problematic, (1/2 the battle won)
the first thing to do (tell me what pC) but turn off all sleep
modes in the CONTROL PANEL + POWER SETTINGS>
do that first. if you can even get the screen to work.
A pc never boots to sleep so.....
the PC can have 2 VGA jacks on the rear.
the PC can have DVI jacks, using those are you
try them all yet?
if you test the PC and it works and the screen works the cable is bad.
omg that screen is new, its even sold now at walmart.
not cheap either, too much, kinda
this is a modern 22" screen, LED>
and do not just go bad, is the power pack there and correct?
if the OSD screen is dead, check power first.
this is the Monitors brain, it works even with the PC dead.
the button is marked menu or select. this is test1.
osd-1z31dkbg41o2owghj0fas5br-1-0.jpg on my monitor ,heck all 2004 up
it tells you SLeep mode when the PC goes to sleep mode
or shows Power saver mode. live on the screen.
screen power on first sure.
all ways to go black done here.
http://pcdied.com/black-screen.html
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
2answers
Hp2338h monitor goes to sleep all the time. When turned on it displays for a couple of seconds, then message flashes that its going to sleep. Its a not graphics driver board or power saver setting,...
I've seen on a few Windows 7 machines has been the display turning off after only 15 minutes, even though I set the Turn off the Display option to Never. Weird!
You're probably reading this because you've tried changing the power plan settings to Never for everything and your monitor still turns off! This can be very frustrating and usually occurs with new installs of Windows 7, though I've seen it happen on older installs too.
In this article, I'll go through the different ways you can fix this problem. Note that if your computer is on, but the screen is showing No Signal or No Input, you should read my post on fixing blank or black screens. Now let's go through the possible solutions.
Power Options - Control Panel First, we need to make sure everything is set correctly in Power Options. Click on Start and type in power options or go to Control Panel (icon view) and then open Power Options from there.
Click on Start, then Control Panel and then Hardware and Sound, and then click on Power Options.
Click on the Change plan settings link that is next to the plan that is currently selected. In my case, the High Performance plan is selected, so I'll click on the link next to it.
First, make sure that Put the computer to sleep is set to Never. Next, change the Turn off the display setting to whatever value you want it 10,15 min etc.. You don't have to set it to Never if you don't want to. After this, click on the Change advanced power settings link.
Expand Hard disk and then expand Turn off hard disk after. Reduce the value till it gets to Never. Click OK and then click Save Changes on the Edit Plan Settings page.
Screen Saver - Control Panel The second setting you want to check is the screen saver. Go to Control Panel, click on Personalization, and then click on Screen Saver at the bottom right.
Make sure the setting is set to None. Sometimes if the screen saver is set to Blank and the wait time is 15 minutes, it'll look like your screen has turned off.
BIOS, Graphics Card, Monitor The two methods above are the most common reason why your display will turn off after a set amount of time, however, there can be other possible causes.
BIOS - On some computers, the BIOS can have power saving settings that determine how the computer sleeps. These are called sleep modes (S1, S2, S3, S4, and S5). On some computers, you'll see an option called Deep Sleep Control. You may need to disable this in order for the computer to wake up faster.
Graphics Card - If you have a high-end graphics card installed, make sure you have the latest driver and management software installed. If you go through the settings, you may find an option that puts your graphics card into lower power mode or something similar.
Monitor - Lastly, some monitors have power saving features themselves. Usually, the monitor is supposed to go into power saving mode if it doesn't detect any input (HDMI, VGA, DVI, etc), but sometimes it happens unexpectedly.
You'll have to press the buttons on the monitor to get access to the monitor settings. Those are about all the reasons I could think of for your display turning off when it shouldn't. If you have any other questions please post them here ,Best
We Are Here To Help !!
3helpful
My monitor goes to sleep all the time, not
trevor_jody, I hope you have valid HP warranty! If not , then you will need to do some reading at this blog: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ The cheapest way to fix is DIY. But you and only you can determine if you are able to do the required work necessary to refurbish the unit. Swap-in a good unit to use while you are researching the common fixes for your 2338h unit. Your unit still works!!! Just not long enough! Your goal is to make it work for 20 million seconds. Try these other web sites also. www.ccl-la.com/badcaps.htm (site run by "buddymc") and www.badcaps.net , www.lcdparts.net Next thing to do will be to understand the "flashlight test" to determine state of your monitor's "switch-mode-power-supply". Is it in full or partial shutdown mode when screen goes BLACK or BLANK and BLACK? If you can still see Win-desktop after screen goes black, then SMPS is in partial shutdown mode. Blank n black=full shutdown. Do some reading in my and "buddymc" and "budmrtn" fixya profiles by typing our fixya "nicknames" into the "search for solutions or.... " bar at top of fixya screen and then hit enter or click search button. You will also find DIY video clips at YOUTUBE that will also be of some use too!! All that we ask you to do after doing your research is to come back to fixya and tell us if we were of some help and that you have learned something about how your monitor functions and if you have been able to make the decision to DIY or contract out the work needed to restore your unit to like-new condition. Bye for now. 12fixlouie
Monitor reading power lockout when try to shut off
the PC never turns off power to the monitor, it has its own power.
and sure, the monitors all do that 2004 to now. called VISA sleep.
modem has nothing to do with this.
Some monitors have this features called that.
its in your users manual. 2009m?
your page.
https://support.hp.com/us-en/product/hp-value-20-inch-displays/7274733/model/3884700/manuals
the words are clear.
it has power saver mode, turn that off
it has osd LOCK,
but no powerlock. as some do,. as your manual. shows.
page 24 shows.
http://h10032.www1.hp.com/ctg/Manual/c01725831
quote, power button does this.
turns the monitor on and to standby or sleep mode.NOTE:
The power button is located on the top or front of the monitor depending on the model
off , on, and sleep.
my guess you are putting the power button i Sleep mode
a feature of this monitor.
1helpful
Monitor goes to sleep
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
3helpful
Hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
