Question about New Bright Toys
Train silver rail express #1170 can't find off/on switch
3 Suggested Answers
SOURCE:
TKahill
  • 89 Answers
SOURCE: I have a Lionel War
From the impact of the train when it hit the ground, it has probably damaged the sound system beyond repair. There are multiple problems that could've occurred, such as the wires breaking/loosening, or the sound box could have broken. There isn't a realistic way to fix this, really.
Even though it may not have been your fault, you should try to prevent things like this from happening in the future.
As to the 042 switches, this is likely the same problem. You can order replacement switches online to test them and make sure for relatively cheap, however.
There is hope for you, however. Go to the link below to go to Lionel's customer service page. There, you can find replacement parts and service stations that can replace/repair your train for you, for a small price compared to the value of the train itself. Good luck getting it fixed!
http://www.lionel.com/CustomerService/
Posted on May 03, 2011
sflummox
  • 91 Answers
SOURCE: new brite silver rail express
For battery powered New Bright train sets, remove the "coal" from the tender car (behind the locomotive) to insert batteries.
Note that some sets draw power through the wheels, from a wall adapter that clips to the rails.
Posted on Jan 07, 2018
New brite silver rail express
I can find no camera with this description - please can you tell us the make and model ?
Jan 06, 2018 | Toys
I have the wonderland express train won't go around can it be fixed
Yes, but before I took the set to a model train dealer I would check the basics. Depending how the unit is stored I would assume that corrosion(oxide) has built up between the electrical components.
This is so common that it can be assumed to be a normal maintenance activity.
The connections from the power to the track, between the tracks and between the engine wheels and the track.
Setting up on a table top allows for convenient troubleshooting.
A voltmeter provides a good tool for efficient analysis of the electrical circuit.
Using a soft cloth rub/polish the rails to eliminate oxide/grime built up.
Use an eraser to scrub the connections between the rails,
I've included several links to provide you with examples of problems and solutions.
Merry Christmas
Hope this helps?
Troubleshooting Ready To Run Lionel Train Sets
Setting Up Your Lionel Train Set
How To Fix Problem With Lionel Fastrak With Voltage Drop Fastrack Connection Pin Fix
Nov 29, 2016 | Crafts & Hobbies
When I my brand new Lionel train on the track, the red light goes out. Is there a short in the loco?? This isa the Polar Express 73-0218-250 model Xmas is tomorrow!!
I am assuming that the throttle is off when you put the train on the track. If off, then you are correct that there is an internal short in the engine. You might try disassembling the unit and looking for a pinched wire specifically from a roller(s) (center rail pickup). You might also check for a short between a pickup roller and a wheel with a VOM. Make sure the wheel is not the one with the neoprene belt.
Dec 25, 2014 | Lionel The Polar Express Train Set
Will not go forward, but will go reverse
Diagnostic: Poor connection/conduction between carbon brushes and rails.
Solution: Clean carbon brushes and metal rails with solvent. If problem persists you must need to expand the inner carbon brushes' coil spring from the second car.
Jan 09, 2014 | Lionel 11000 Holiday Tradition Express...
I have an 1985-1986 talking silver rail express train set and it will move just a little ways and then stop. Has something happened with in the gear system?
My son recently disassembled one with the same symptom. He found one of the small gears in the drivetrain had split -- causing it to bind and limit motion to a inch or so. It's been in the family 25 years, but we elected to junk the locomotive :(
Nov 09, 2013 | Echo Toys
How the power is transfered to the train?
the power from the wall outlet is ( transformed) to 17voilts AC and comes out on posts on the transformer that red and black wires then are connected to the track The rails on the track are entergized and the wheels and the center pickup ride on the track and transfer the power ot the locomotive. the center rail is common and the outside rail is motor power or whisle power.
Dec 25, 2010 | Lionel Trains The Polar Express O Gauge...
Hello: Train won't move
CHECK FOR SWITCH ON BOTTOM OF TRAIN
Dec 07, 2008 | New Bright Toys
Toys Logo
439 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
